| Second Generation MINI Tuning Tuning the second generation MINI Late 2006 - Present |
| You will need... A Torx driver set to remove the screws from the front of the air filter box and the two screws that hold the turbo inlet pipe onto the front of the air filter box. A medium sized Philips or cross-head screw driver to remove the small screws that hold the air filter in place inside the air filter box. A medium sized flat blade screw driver to undo the hose clip on the intake side of the turbo. And about 30 minutes to do the job and install the parts when the engine is cold as the turbo gets ****ing hot!!! You don't want to burn your hands, do you? With the JCW stage 1 kit, the ITG filter, Works turbo inlet pipe and a tank full of decent petrol, you should be getting about 205 to 208bhp? And if you get the Miltek hi-flow cat, you'll be up to about 215 to 218bhp....l like me! Have fun! P. |
| Right, need to get hold of a TORX set then. Might just see if the dealer will slyly fit it for me when I go and pick it up, no harm in trying I guess. How about the bit that branches off, the one that my highly dodgy attempt in paint shows? ::.. 2007 JCW Stage 1..:: --- Modern MINI Oscars Winner 2008 --- |
| Has anybody who's installed the rigid intake tube on their MCS experienced any problems at all? I put it on mine, felt like a good fit, especially with the clamp tightened down snug. I have read that the diameter of intake for the JCW turbo vs the MCS turbo is different and that by installing the rigid tube on an MCS it can work loose and a cause catostrophic problem. Did anybody take the rubber seal from their stock MCS tube and put it inside the rigid tube by any chance? |
| Tags: filter, inlet, itg, jcw, r56, rigid, turbo |
| Retrofit JCW Rigid Intake Pipe with dealer-fit JCW engine kit | TDLC | Second Generation Works | 4 | May 23rd, 2010 08:46 PM |
| PDF: Fitting Guide for JCW Steering Wheel & Retro Fit Chrome Line | JpMcC | Second Generation Interior & Ice | 1 | Dec 17th, 2008 11:58 PM |
| ITG replacement JCW filter only £41 | Vecchio Engineering | First Generation Works | 5 | Nov 12th, 2007 10:10 PM |
| JCW Y PIPE Inlet Query | bassetm1 | First Generation MINI Tuning | 6 | Jun 19th, 2007 09:55 PM |
