| Second Generation MINI Tuning Tuning the second generation MINI Late 2006 - Present |
What PANEL Air Filter to Use? I am a new Clubby owner and understand that simply upgrading my OEM panel air filter to a Foam air filter, I can get a little more umph out of my engine. True? Recommendations? Thanks! |
| The whole range of ITG Profilters for the R56's can be found here! Engine Performance - Welcome to Vecchio Engineering - The BMW and New Mini Tuning Specialists The ITG panel filter can easily be swapped out for warranty work with the dealer. ALWAYS tell your insurance company. I cannot stress this enough! In most cases they will not charge you a thing. After all the insurance people reserve the right to VOID your policy! |
| why does it invalidate the warranty ? it might be a stretch to call it a consumable, but the paper ones do need replacing ultimately, and Ive not read anything that says you shouldnt replace it yourself, or only seek a dealer replacement for it I can understand removing the air filter completely could be seen as a bad idea for an engine warranty claim but replacing the existing filter with an acknowledged better air filter, dont quite see where the problem is.Stono |
This is so true...Air Filters are primarily there to filter the air, so getting a good filter efficiency is more important than letting more air through. Replacing an OEM filter with an inferior (less efficient) filter could easily invalidate the warranty if the engine fails due to ingress of particulates. I've been working in the Induction business long enough to realise that there is a fine line between increased performance and high filtration efficiency. |
A dirty filter means its doing its job. If I had a clean filter at the time of replacement, I would be very worried - this means all the **** has gone into the engine!!! Paper filters are about 99.8% efficient - 0.2% of all dirt gets into the engine. Cotton filters are between 92-97% efficient. Foam filters are between 30-70% efficient - thats a lot of dirt getting into the engine - who knows what its doing? |
| Tags: air, filter, intake, oem, panel |
| Best panel air filter? | chrisrue@btinternet | First Generation MINI Tuning | 3 | Jan 20th, 2009 06:57 PM |
| Panel Air Filter | flatland69 | First Generation MINI Tuning | 3 | Sep 23rd, 2007 08:49 PM |
| Air Intake Panel Filter / K & N typhoon effects on performance and insurance | TShaw | First Generation MINI Tuning | 5 | Aug 22nd, 2007 03:54 PM |
| Foam Air Filter Vs. K&N Air Filter--which one to choose? | Zipperblues | First Generation MINI Tuning | 14 | Jul 31st, 2006 12:24 PM |
| How do I change my air filter panel? | Zeede | First Generation MINI Tuning | 12 | Nov 5th, 2003 01:35 PM |
