| Second Generation MINI Tuning Tuning the second generation MINI Late 2006 - Present |
EVO/JCW Brembo front calipers Has anyone tried to fit a set of EVO Brembo Calipers onto a Mini? looks like they should fit and make a cheaper brake upgrade conversion???? |
| size of disk made for evo caliper Disc size for caliper: EVO 320mm X 32mm JCW 294mm X 22mm Looks like there is a 10mm difference between them in width... Would that effect??? and Would they just bolt on the mini knuckel or you would need to make a flange to fit them on???? thanks Last edited by splitboy888; Apr 29th, 2009 at 08:41 AM. Reason: rewording |
| With just over 250 to 300pounds for a good pair of EVO Brembo calipers you could have better performance brakes than BBK's, hehh believe it or not some times its good to waste time as you gain more knowledge. |
| Will JCW BREMBO 4 Pot sport calipers fit on My R105's without modification? | splitboy888 | Second Generation Works | 3 | Apr 9th, 2009 09:57 AM |
| JCW Brembo Front brake Kit - R56 | hgsbnt | First Generation MINI Cooper | 1 | Feb 13th, 2009 10:32 AM |
| WOW £35.00 Brembo Calipers | super c00per | First Generation MINI Exterior | 4 | Aug 2nd, 2008 09:17 PM |
| JCW Front Brake Calipers | Brian Cooper S | Wheels, Tyres & Brakes | 8 | Jan 4th, 2006 08:52 PM |
