Now i'm sure most if not all of you are aware of the issue attaining to the N14 engine, which has the issue of excessive carbon build up on the inlet valves ?
The usual method is to fit an oil catch can or use a cleaning additive such as Seafoam, BG K44 etc etc or maybe both, there has been discussions and I have mentioned this too, about the fitment of water/meth injection to help remove and control the excessive carbon build up.
For a while now I have been testing another solution, and this is to completely remove the rear PCV hose, which feeds the crankcase gas oil mist residue directly into the base of the inlet manifold, which in turn is pulled up into the incoming air flow and finds itself being burnt onto the inlet valves.
So the following photo's show what I have done as another alternative to combat this issue.
And all is well and good.
