PCV hose, delete. - Page 3 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > MINI Technical Forums > MINI Engine & Drivetrain Tuning > Second Generation MINI Tuning
Tuning the second generation MINI Late 2006 - Present
  #31 (permalink)
Old Aug 26th, 2012, 07:03 PM
Local Time: 01:09 PM
Does anyone know of any contact in the US to get these caps?
  #32 (permalink)
Old Dec 15th, 2012, 09:17 PM
Local Time: 08:09 PM
[quote=Czar;3828269]If during long periods of idle, enough internal pressure does build, it will push open the PCV valve flap, releasing the pressure, however if this valve flap does not open for one reason or another, there is an external pressure release valve, on the back of the cam cover, on all December 2008 built engines onwards.
See image below, the top cam cover is in the image is fitted with the external pressure release valve.
Hi Czar,
Does this mean on a 2007 MCS I shouldn't apply this pcv deletion mod? Because of the lack of a the external pressure release valve?
D
  #33 (permalink)
Old Dec 15th, 2012, 09:32 PM
Zanhar25
I've read alot about this on lots of different sites toda and I'm thinking of doing this mod to my wifes MCS.
What I'd like to know is has anyone done this and has is solved the heavy oil consumption problem a lot of 2nd generation MCS owners have including my wifes.
  #34 (permalink)
Old Dec 16th, 2012, 10:44 AM
Not sure it solves any oil consumption problems, just helps the valves getting coked up?
  #35 (permalink)
Old Dec 16th, 2012, 02:02 PM
Zanhar25
The reason the valves coke up is because oil mist is being sprayed into the engine so surely by default if oil isn't being sprayed into the engine oil consumption should improve??
Just a thought
  #36 (permalink)
Old Dec 16th, 2012, 03:25 PM
The N18 engine doesnt have the same system but owners still seem to complain about the amount of oil usage still?
  #37 (permalink)
Old Dec 16th, 2012, 05:29 PM
United Kingdom Male View Czar's Classified Ads
[quote=MiniMotoR56;3847931]
Hi Czar,
D
You can fit the blanking caps even though you don't have the external pressure relief valve, as providing the PCV valve flap which feeds into the air intake pre turbo is functioning, this will relieve any excess pressure.
Fitting of the blanking caps can help reduce oil consumption!
Just a thought
The oil mist isn't sprayed it is vacuum drawn through the intake tract.
The N18 engine still has two PCV systems just like the N14, however unlike the external rear PCV feed to the intake manifold, the N18 engine's rear PCV is internal which still feeds oil mist direct into the intake runner tract in the cylinder head.
Performance Powered By Thought.
Engineered Horsepower.
  #38 (permalink)
Old Jan 5th, 2013, 05:26 PM
Local Time: 07:09 PM
Male View arbi12's Classified Ads
pcv plugs
i fitted these blanking plugs on 09 mcs, on start up i get a smell of oil think this is coming from vent on rocker anyone else noticed this?
These are now fitted as standard to rcz 207 ds 3 models fitted with this engine, instead of redesigning rocker and manifold so pug/cit are addressing this issue but mini are blind to the problem, have spoke to tech after tech at bmw and there s no problem?
  #39 (permalink)
Old Jan 12th, 2013, 11:39 PM
England
I have done the delete to my 57 MCS & get the smell when stationary just after starting the engine & when i'm outside after a run. The inside smell goes away very quickly when i get moving.
Tab
  #40 (permalink)
Old Feb 12th, 2013, 07:49 PM
England Male View timp7748's Classified Ads
This is interesting. I wish I knew of this when I still had my MCS.
  #41 (permalink)
Old Feb 23rd, 2013, 09:29 PM
England
I fitted a dump valve the other day, the smell is a lot stronger now. I'm going to have to get a Oil Catch can to try stop the smell.
Tab
Tab
intake hose resonator delete vinniecooper First Generation MINI Tuning 1 Jan 22nd, 2011 12:55 PM
forge Intercooler Reasonator delete hose argyris Second Generation MINI Tuning 20 Jul 28th, 2009 08:59 PM
Cleaning... Without a Hose.. envy Maintenance & MINI Care 10 Jun 12th, 2009 07:42 AM
Fitting Resonator Delete Hose Rosco Second Generation MINI Tuning 4 Feb 3rd, 2009 02:26 PM
PCV hose pics? DarkMiniCooperS First Generation Faults & Fixes 5 May 10th, 2004 02:37 AM
