R56 Dump Valve Sound/ - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > MINI Technical Forums > MINI Engine & Drivetrain Tuning > Second Generation MINI Tuning
Tuning the second generation MINI Late 2006 - Present
Old Nov 2nd, 2011, 11:07 PM
Hammo18
Local Time: 03:31 AM
My Cooper S Seems to be giving a whistling noise when you give it the beans which I guess is the turbo, but then when changing gear a swish can be heard, which sounds exaclty like a quiet dump valve..any ideas why?
2007 S if that helps
Mark
Old Dec 20th, 2011, 08:59 AM
BlueBeastie's Avatar
Local Time: 04:31 AM
South Africa Male
Mine does the same. It's the blow off valve which I'm assuming is the same a dump valve.
Old Dec 20th, 2011, 05:31 PM
Hammo18
mine ended up being the turbo inlet pipe which was on loosely! Miss the woosh sound now
Old Dec 20th, 2011, 06:38 PM
Nick007's Avatar
Czech Republic Male
MCS (or most of normal turbo cars) don't have blow-off valve, but rather bypass adapter, so the air isn't blown into atmosphere but to turbo's cold air intake.
@hammo
If you want to hear the whoosh, just get CAI, for example from Alta.
Mini Cooper S (2007), 158 kW and 312 NM.
Old Jan 23rd, 2012, 09:31 PM
******** noise generator
This is probably a bit late, but what you have on the Cooper S is a ******** noise generator that attaches to the bulkhead. Thats what you can hear.
Tab
Quote: Originally Posted by Nick007 (original)
MSC (or most of normal turbo cars) don't have blow-off valve, but rather bypass adapter, so the air isn't blown into atmosphere but to turbo's cold air intake.
@hammo
Dump Valve Andy0808 Second Generation MINI Cooper S 5 Feb 5th, 2009 05:53 PM
Blowoff Valve/ Dump Valve on JCW? googoogaga Second Generation Works 2 Feb 2nd, 2009 05:35 PM
Dump valve sound?? pardonator First Generation MINI Tuning 1 Sep 5th, 2007 01:30 PM
Dump valve Rakey First Generation MINI Tuning 40 Oct 22nd, 2006 07:10 PM
dump valve sound from cooper in italian job cannondale MINI in the Media 5 Oct 8th, 2003 07:42 AM
