What oil to put in my 59 Reg Cooper S - MINI Cooper Forum
Second Generation MINI Tuning
Tuning the second generation MINI Late 2006 - Present
post #1 of 7 (permalink) Old Jan 13th, 2014, 06:33 PM Thread Starter
Local Time: 05:04 PM
Need to top my oil up on my car and was wondering if people had preferences on what oil to use? I was thinking of using Commo 5w-30 fully synthetic.
sxcsam is offline
post #2 of 7 (permalink) Old Jan 13th, 2014, 08:25 PM
Dermottdog's Avatar
Local Time: 04:04 PM
You should use the best oil you can afford. Unfortunately, that's not Commo. You should visit the Castrol web page. You can then enter your reg number and it will give you the oil you need. I use Castrol Edge 0W-30 (as do many others on here).
Dermottdog is offline
post #3 of 7 (permalink) Old Jan 14th, 2014, 09:54 AM
Totally agree,use the best.
al the mini man is offline
post #4 of 7 (permalink) Old Jan 15th, 2014, 04:44 PM
Local Time: 11:04 AM
use a REAL synthetic group IV oil. turbo's need top quality oil to prevent breakdown, in the USA i use Amsoil signature series oils in everything. IMO an 0W oil is not needed unless you get VERY cold weather, i used 10-30 in my modified to almost 300 hp 1.8T jetta-bora for almost 200,000 miles before trading in. a group IV 10-30 uses little to NO weak viscosity index improvers. if its very cold there amsoil's 5-30 signature series has a pour point of -60 F that should suffice. i believe on your side of the pond group III dino oils cannot be labeled synthetic as in the USA, thank castrol-BP for that!!
rodhot is offline
post #5 of 7 (permalink) Old Jan 15th, 2014, 07:15 PM
Dermottdog's Avatar
Can't disagree with that. However, as stated, if you check out Castrol.com and select the oil finder box, it will allow you to input your registration plate for your car and provide you with the correct oil. In my case, a 2011 FJCW, it suggests Castrol Edge 0W-30. I don't know about other parts of the world but Mini in the UK recommends Castrol oils (stamped on the dipstick bracket) and they recommend 0W-30 and that's good enough for me.
post #6 of 7 (permalink) Old Mar 4th, 2014, 03:28 PM
SGT Slaughter & Farm Girl
Local Time: 12:04 PM
United States Male
United-States Oil is not the same........
Just be careful, Mini is unique. They want/require you to use full Synthetic that meets (BMW LL-01 Specs). NOT ALL SYNTHETICS DO. The oil from your Mini dealer does so does 0w-40 Mobil 1 European Formula (hard to find). I have used AMSOIL and ROYAL PURPLE for years on other vehicles but dont even know if they meet the Mini Specs! Someone else mentioned about the Turbo.... Yes Turbo's spin just a little and get a little warm you could say HeHe. So be careful, do your Mini research. I should check AMSOIL & ROYAL PURP, GREAT OILS AND EASY TO GET!!!!
Mini_drive is offline
post #7 of 7 (permalink) Old Mar 18th, 2014, 03:52 PM
from what i read oils labeled synthetic in europe must be real-group IV + or V oils. in the USA group III highly refined dino oils are legally "synthetic". as long as you meet the spec any brand is good. my 2012 triumph bonneville recommended mobil I in the book, triumph got a "deal" with castrol now and thats their recommendation now. a quality group IV + or V oil is money well spent IMO!
rodhot is offline
Oil leak mini cooper s 05 reg Mini-jase Maintenance & MINI Care 9 Dec 14th, 2013 11:34 PM
Oil question, 52 plate mini cooper S, help a newbie! Lisaa-wilson General Discussion 11 Nov 30th, 2013 12:34 AM
Low Oil Pressure - Filter Debris in Oil System??!! MissMac General Discussion 5 Apr 1st, 2013 11:23 AM
Mini cooper s r53 37,000 using oil is this normal leedslad Maintenance & MINI Care 11 Feb 4th, 2013 11:26 PM
Oil consumption Mini Cooper s N18 engine peterhellawell Maintenance & MINI Care 1 Jan 24th, 2013 10:11 PM
