Mahle or CPS forged pistons? - MINI Cooper Forum
Second Generation MINI Tuning
Tuning the second generation MINI Late 2006 - Present
post #1 of 3 (permalink) Old Jan 19th, 2014, 06:09 PM Thread Starter
Local Time: 05:26 AM
Quoted: 11 Post(s)
Im thinking of making an upgrade to my R56S wngine with forged pistons. Seems that the piston rings are in bad shape (consuming too much oil) so i probably have to open the engine and replace them, but once i do so why not put forged pistons in there. Friends have advised me for those two brands, Mahle and CPS but i have no idea which of the two is best! Any help on this and where from can i get them as cheap as possible?
genik is offline
post #2 of 3 (permalink) Old Jan 22nd, 2014, 09:36 AM
Local Time: 06:26 AM
Quoted: 1 Post(s)
England
Have you had the diagnosis done by someone you can rely on? Not heard of this on the R56, its usually the turbo seals, or the breather system.
What's the compression like compared to what it should be? Have you had a look inside the cylinders with a boroscope?
Tab
Tabintab is offline
post #3 of 3 (permalink) Old Jan 22nd, 2014, 09:32 PM Thread Starter
Quoted: 11 Post(s)
Where is the turbo seals and breather system located?
Yes the technician had a look with his camera and on the pistons heads he saw carbon along with burned and fresh oil stains!
genik is offline
Tags: , ,
