Engine Bearings - MINI Cooper Forum
Second Generation MINI Tuning
Tuning the second generation MINI Late 2006 - Present
post #1 of 3 (permalink) Old Apr 5th, 2014, 02:07 AM Thread Starter
Local Time: 08:34 AM
Engine Bearings
Hi, The Bearing Dilemma..... I have been working on a 2007 MINI Cooper S r56 N14.
For one reason or another I discovered that though my MINI was running well its cylinders were in a bad way. So I pulled the engine and am rebuilding it.
I have a beautifully honed block and new pistons to match. I would like to get new engine bearings however Ive run into some difficulty.
The information I have for selecting the main bearings calls for codes on the crankshaft, and the top and bottom halves of the block. My machinist and I only found the block code on the top half, left of the oil filter housing.
To make matters worse there are no sizes in the parts descriptions. so I can not just measure.
I have also not found any other manufacturers that make N14 bearings.
I have asked MINI staff for help but they have no further information to share. I have considered getting some test bearings to measure but I have been told it would take up to 5 weeks, double that and it would be 10 weeks.
Does anyone know the proper specifications for the bearings and where I can get them?
Euler-Spiral is offline
post #2 of 3 (permalink) Old Apr 5th, 2014, 09:13 AM
Local Time: 09:34 AM
Quoted: 53 Post(s)
Go and ask one of the MINI tuning specialist here on the forum 1320 MINI is it? Im sure they will know or can supply??
The Nun is offline
post #3 of 3 (permalink) Old Apr 5th, 2014, 01:55 PM Thread Starter
Hi, Actually I was looking at the cat cams they have on there site, so I left them a message. Does any one know the bearing clearances? The Bently manual I have leaves this stuff out. Thanks
Tags: , , ,
is my engine overheating or am i just paranoid? emirius Second Generation Faults & Fixes 3 Jun 24th, 2015 09:26 PM
Time Chain Tensioner failure and Engine shut down jhl2435 Second Generation Faults & Fixes 2 Mar 1st, 2014 08:45 PM
Mini engine dispute SarahH General Discussion 9 Dec 11th, 2013 11:39 PM
Cracked engine block? Help please?! rhutch First Generation MINI Cooper 2 Dec 16th, 2012 11:24 PM
BMW three-cylinder MINI engine revealed mab01uk MINI in the Media 1 Oct 9th, 2012 11:42 PM
