R56S leak down test - MINI Cooper Forum
Second Generation MINI Tuning
Tuning the second generation MINI Late 2006 - Present
post #1 of 11 (permalink) Old Apr 13th, 2014, 02:24 PM Thread Starter
Local Time: 07:35 AM
Quoted: 11 Post(s)
R56S leak down test
How does one do a leakdown test on an R56S? Ive searched on youtube but i dont see anyone done such a test on an R56S!
genik is offline
post #2 of 11 (permalink) Old Apr 14th, 2014, 01:46 PM
Why do you feel you need to do a leakdown test. The process is just the same as any leakdown test on any other car.
Big_Nige is offline
post #3 of 11 (permalink) Old Apr 27th, 2014, 05:49 AM Thread Starter
Quoted: 11 Post(s)
I need to see where all the oil that the car looses (and its not dripping) goes, is it lost through the piston rings, through the valves, where?
Can the leak down test show if its leaking from the valves?
genik is offline
post #4 of 11 (permalink) Old Apr 27th, 2014, 07:55 AM
Hi ya
How much oil is it using
marque is offline
post #5 of 11 (permalink) Old Apr 27th, 2014, 08:51 AM Thread Starter
Quoted: 11 Post(s)
Originally Posted by marque View Post
Hi ya
700ml per 1000km
genik is offline
post #6 of 11 (permalink) Old Apr 27th, 2014, 12:26 PM
Leakdown test isn't really for finding oil leaks it's to basically show how airtight the combustion chambers are and from there you can identify if the valve guides are worn or the piston rings and what the variance is across the cylinders.
Wikipedia link sill save me from typing it out.
Leak-down tester - Wikipedia, the free encyclopedia
Big_Nige is offline
post #7 of 11 (permalink) Old Apr 27th, 2014, 12:31 PM Thread Starter
Quoted: 11 Post(s)
If there is a piston ring sealing issue can't that be a reason to where all this oil is going?
genik is offline
post #8 of 11 (permalink) Old Apr 27th, 2014, 12:40 PM
If you are burning oil you can usually tell if it's valve guides when the give it some beans and then back off suddenly and hit the throttle again after a few moments you will get a guff of burnt oil smoke out the exhaust. Usually notice this if you are coming of the motorway onto a slip road and stopping at the junction before moving off again. If it's getting past the piston rings an engine usually burns the oil under load/hard acceleration.
Though this isn't always down the worn components and can be something as simple as a blocked breather system. Also you can burn oil through worn turbo or supercharger seals.
Some oil use is acceptable, the factory guide on my 911 is anything from 0.5l-1l per 1000 miles is within the accepted limits.
Big_Nige is offline
post #9 of 11 (permalink) Old Apr 27th, 2014, 03:33 PM Thread Starter
Quoted: 11 Post(s)
Thanx Nige but if this is so, why wasn't there any oil consumption before the 40.000km mark?
genik is offline
post #10 of 11 (permalink) Old Apr 27th, 2014, 03:39 PM
Are there visible signs of oil burning from the exhaust?
Big_Nige is offline
post #11 of 11 (permalink) Old Apr 27th, 2014, 03:45 PM Thread Starter
Quoted: 11 Post(s)
What exactly would i be looking for and if so, should there be signs from the exhaust?
genik is offline
Small water leak only in the morning akaymc First Generation Faults & Fixes 11 Mar 20th, 2014 07:43 PM
Oil Leak or Coolant leak MeanGreen7 First Generation MINI Cooper S 3 Feb 17th, 2014 04:17 PM
Mini C 2002 - Engine oil leak found thedynamix First Generation Faults & Fixes 6 Apr 5th, 2013 06:57 PM
