2007 cooper s air filter help!! - MINI Cooper Forum
Second Generation MINI Tuning
Tuning the second generation MINI Late 2006 - Present
post #1 of 6 (permalink) Old Apr 21st, 2014, 02:44 PM Thread Starter
Local Time: 06:19 PM
United-Kingdom 2007 cooper s air filter help!!
Hi guys and girls
I am going to upgrade my standard air filter to an after market I.e. Piper cross or k&n....
Which do you suggest or have fitted on yours
It's to fit my 2007 cooper s
Any help is much appreciated
mf0017 is offline
post #2 of 6 (permalink) Old Apr 21st, 2014, 02:51 PM
Local Time: 05:19 PM
Hi ya
ITG if your just replacing the standard filter with like for like
marque is offline
post #3 of 6 (permalink) Old Apr 21st, 2014, 08:32 PM
I my mind there isn't any choice, if your going for a replacement filter. It has to be the K&N, think the part number is 33-2936. Check the size first, 362mmX146mmX22mm before you buy.
rogbro is offline
post #4 of 6 (permalink) Old Apr 21st, 2014, 10:59 PM Thread Starter
Thumbs up
Rogbro thanks for the reply does this work well for you as I have heard people say they are soaked it to much oil which makes sensors go?
Marque do you have a part number or know where I can purchase this from
Cheers guys
mf0017 is offline
post #5 of 6 (permalink) Old Apr 21st, 2014, 11:28 PM
Hi ya
These guys are help full
Induction & Filtration - Induction & Exhaust - Mini Generation 2 - Vecchio Engineering
http://www.camskill.co.uk/products.php?show=60211
Hope this helps just make shore it correct for your model ie flat panel or cylinder type depending on your airbox.
Your should be a flat panel but just check
The K&N are not a bad filter, but with all cleanable filters people do go a bit to made re oiling them
marque is offline
post #6 of 6 (permalink) Old Apr 22nd, 2014, 10:52 AM Thread Starter
I will probably go with the k&n does any one know the correct part number?...
mf0017 is offline
Tags: , ,
Mini Cooper Oil and Filter Service with EGR Blank andreweaves Maintenance & MINI Care 5 Aug 20th, 2016 01:14 PM
Broken Dooper Air Filter Box / housing FATT Second Generation Faults & Fixes 6 Feb 27th, 2014 08:48 PM
R53 air filter question Hollywood First Generation MINI Cooper S 13 Aug 21st, 2013 03:52 PM
Newbie with a 2007 Mini Cooper and a 2010 Mini Cooper S JCW Converible dcphotos Welcome New Members 0 Sep 18th, 2012 01:05 AM
which panel air filter you used on your mini and why? tommytse22 First Generation MINI Tuning 12 Aug 19th, 2012 08:13 PM
