Mini Cooper '05 Auto Gearbox Failure Conondrum - MINI Cooper Forum
Second Generation MINI Tuning
Tuning the second generation MINI Late 2006 - Present
post #1 of 2 (permalink) Old Jul 11th, 2014, 11:43 AM Thread Starter
Local Time: 09:42 AM
United-Kingdom Mini Cooper '05 Auto Gearbox Failure Conondrum
Hello Forum,
I have a Mini Cooper 2005 Automatic; the gearbox starting being funny;
Initially the revs were going too high while changing from 1st to 2nd gear.
I disconnected the battery hoping it was an ECu issue. It worked for a while (rev were now too low when changing).
I noted that when changing from Park to Drive the gearbox had a small lag of about half second to engage with a little bump.
Later on.. total disaster... the gear would not change from above 1 at all..
A diagnostic unveiled the following messages codes:
1787 gearbox ratio actuator open circuit.
698 gearbox control unit
EGS no communication
ABS no communication
Those this points to the transmission slipping inside and requiring the sheave and chain replacing ?
I am not familiar with error codes, but it does not look like there is a clear indication of mechanical part broken inside the gearbox.
On one hand :
-I am worried I will have to pay for an expensive gearbox dismount when in reality it's an electrical issue only.
On the other hand I am worried that the mechanical repair does not solve the issue and I get dragged in endless repairs involving Ecus.
Although in good conditions (1 previous owner only, all paper work perfect etc.) my mini is 115 k miles, so thinking whether I should repair it all and find alternative solutions.
Thank you very much anyone could help and advise whether the logs do actually points at mechanical failure / advise what to do next
Kate mini is offline
post #2 of 2 (permalink) Old Jul 11th, 2014, 11:52 PM
mab01uk's Avatar
Local Time: 08:42 AM
Quoted: 1 Post(s)
You may get a better response here in the CVT section:
First Generation CVT & Automatic - MINI Cooper Forum
mab01uk is offline
CVT Transmission Failure slaybalj First Generation CVT & Automatic 143 Jun 10th, 2016 03:24 AM
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 04:15 PM
New 14 plate Mini Cooper SD Coupe Nightmare Kickboxkel Welcome New Members 7 Apr 4th, 2015 01:33 PM
Mini HQ - Terrible ethics for the customer. jobforacowgirl Dealership Feedback 11 May 22nd, 2014 06:36 AM
