Retrofit JCW Rigid Intake Pipe with dealer-fit JCW engine kit - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI John Cooper Works, GP and World Championship 50 > Second Generation Works
Second Generation Works MINI John Cooper Works and MINI WC50 2007 - Present
Old Jan 31st, 2009, 05:35 PM
TDLC's Avatar
Local Time: 03:34 AM
United Kingdom Male View TDLC's Chili Red & White 2nd Gen MINI Cooper S Profile View TDLC's Classified Ads
Trawling through the FAQ and other forum posts still left me with the following burning questions...
Does any of you have the JCW rigid intake pipe fitted on their JCW stage 1 kitted "S"? I saw this item on Genuinemini.co.uk and got more than a bit curious whether the "smoother power delivery" it promises, is actually noticeable when giving the car a good workout and what other handling benefits people have noticed (if any). Does it increase torque, or does it merely change the curve?
Part II of the question is whether fitting the JCW rigid intake pipe would void the TLC on the car, or come with limitations on the warranty. One the one hand, it is an OEM part, but then again not fitted as standard on an "S" and not even on a JCW Stage 1 kitted "S".
Thanks in advance for your comments!
Jurgen
Old Jan 31st, 2009, 09:59 PM
MJS's Avatar
MJS
United Kingdom View MJS's Chili Red & Black 2nd Gen MINI Cooper S Profile
do a search, theres loads of info on this...
it's literally a 2 minute job to swap, it does make a small difference, a worthwhile mod.
I don't think swapping it will make any difference to your warranty
Old Feb 1st, 2009, 09:52 PM
Tara&Paul's Avatar
Local Time: 02:34 AM
I have the rigid turbo inlet pipe fitted to our JCW Stage 1 tuned R56.
The rigid pipe improves the air flow into the turbo, which makes the turbo spool up quicker which makes the engine more responsive. I've also heard that the original soft rubber turbo inlet pipe can partially colpase at high rpm when the car is driven hard?
Fitting the pipe will not void your warranty as its an original BMW part.
P.
Old Feb 1st, 2009, 10:10 PM
TDLC's Avatar
I have read something similar.
Thanks for your comment
Old May 23rd, 2010, 07:46 PM
I too are having the stage 1 tuning kit fitted next week and thinking about the rigid intake pipe. Should i be staying clear of this mod?
dealer fit JCW question ChrisGJ Second Generation Works 11 Feb 16th, 2009 10:01 PM
Madness JCW Intake Filter Kit? sam_a156 First Generation MINI Tuning 0 Feb 8th, 2007 09:41 PM
JCW Engine Kit & JCW Airbox venox22 First Generation MINI Tuning 2 Aug 26th, 2005 12:01 PM
will dealer fit JCW exhaust ? supercharged99 First Generation MINI Tuning 1 Aug 19th, 2005 09:38 PM
