Heavy oil usage - MINI Cooper Forum - MINI2 Mini Cooper Forums
Go Back   MINI Cooper Forum - MINI2 Mini Cooper Forums > Model Specific MINI Forums > MINI John Cooper Works, GP and World Championship 50 > Second Generation Works
Second Generation Works MINI John Cooper Works and MINI WC50 2007 - Present
Old Nov 30th, 2011, 06:06 AM
Fozzy's Avatar
Local Time: 04:43 AM
Scotland Male View Fozzy's Pepper White & Body Color 2nd Gen MINI John Cooper Works Profile
Heavy oil usage
My car uses 1.2 litres or oil every 620 miles.
Mini say this is border line heavy usage and that they'll do nothing.
Have to to my car up with oil every month.
So to everyone out there check ure oil!
JCW
Old Nov 30th, 2011, 05:43 PM
Local Time: 05:43 AM
Hi ya
It Does sound heavy it could be a few thing causing it
But if I was you get a leak down test carried out make shore the rings and valves are ok.
Then invest in a catch tank, the turbo acts as a hover and coupled with the PCV system you will loose oil though the inlet track, which also causes a carbon problem, the catch tank if installed right will reduce this then you can monitor the oil consumption.
Hope this helps a little
Old Dec 7th, 2011, 03:41 PM
Local Time: 09:43 PM
United States Male
Make sure you are using the proper recommend oil brand and weight.
Many have seen consumption problems because of using an inferior oil type / weight.
- Erik
2009 Mini Clubman (R55) John Cooper Works [JCW] - 1.6 liter turbocharged 16v I4
average usage brake pad help please? matt_croft Wheels, Tyres & Brakes 3 Mar 8th, 2009 07:21 PM
fuel usage lisa30b Maintenance & MINI Care 24 Oct 31st, 2007 02:06 PM
Oil Usage Phat_Mini General Discussion 5 Jun 6th, 2003 07:31 AM
Screenwash Usage Jazzy Jase First Generation MINI Exterior 20 Jan 16th, 2003 09:07 AM
Oil usage -is this normal ? Gee4orce Maintenance & MINI Care 10 Dec 19th, 2002 08:53 AM
