GizzmoUSA
Tags: , ,
Old Feb 24th, 2008, 03:21 PM   #1
TunerTools
MINI2 Sponsor
TunerTools's Avatar
Local Time: 10:08 AM
Group Buy: Gizzmo KMon Knock Monitoring Kit
Dyno Tuners - are you using the most accurate knock detection for your customers?
GROUP BUY - US & CANADA ONLY
UK customers contact GBE Performance UK (link on the GizzmoUSA site)
In quantity of 3 or more, delivered in one order to the same address we can sell Gizzmo Electronics KMon Professional knock detectionand monitoring system at an additional 10% off the MAP pricing shown. 5 or more, 15% and 10 or more 20% off MAP.
Key here is that it's one order, one payment and one delivery address. You and your mates work out who's to organize the purchase.
Please note that this is for North American MINI2 members and sponsors only. For UK customers, see the dealer list on the GizzmoUSA.com site for link to GBE Performance UK
The Gizzmo KMon professional knock monitoring kit takes tuning to the next level. The KMon was designed with leading tuners for tuners with endless hours of dyno development as a major component in the research and development process.
Simply put: There is nothing else on the market like the Gizzmo KMon
Each headphone can be independently configured with the included Gizzmo KMon software to listen to different knock sensors simultaneously; e.g. on a RB26DETT you could configure the left headphone to the front of the motor and the right headphone to the sensor on the rear of the motor or on the Z07 Corvette, one sensor could be used for the right bank and another for the left bank.
There are two headphone jacks for the convenience of training a tuner or a second set of ears when tuning. The knock sensors used for the Gizzmo Kmon are the Bosch donut type that allow a 10mm threaded bolt through the center for easy mounting. The software allows you to tailor the knock channels individually to the motor in addition to setting up the headphones as you desire. It is also possible to set the headphones up so that they are silent until a warning threshold is reached e.g. you can set a warning level of 60% and if this threshold is exceeded the headphones will emit a loud, sharp buzz.
The Kmon also has two analog outputs so that you can log the knock levels into a dyno or datalogging tables for comparisons against air fuel ratio, turbo boost etc.
On the side of the Kmon are 4 LED’s; one indicates power, one flashes showing communications and 2 ultra bright LED’s illuminate if the knock threshold (previously explained) has been exceeded. Internally thing the Kmon is armed with 5 processors. 2 are 20mhz DSP processors (1 per knock channel), 2 are 48mhz RISC processors for number crunching, control and communications and the last processor assures accurate timing alignment.
KMon Knock Monitor Features Include:
  • 2 independent audio output channels
  • 2 independent Knock input channels
  • Each knock channel has configurable sensitivity
  • Center frequency
  • Bandpass width
  • Real-time audio / visual monitoring for each channel
  • Configurable knock warning levels for each channel
  • Real-time replay of data-logs for each channel
  • Left and right headphones can be dedicated to separate knock channels
  • Pre and post audio filtering for each independent knock channel
  • High speed USB2 interfacing
  • Plug & Play, no external power supply needed
The KMon Knock Detection & Monitoring Kit Comes with:
  1. KMon Knock Detection & Monitoring Digital Processing Module
  2. 1 Bosch 10mm knock sensor (see below for additional sensor & loom)
  3. 1 KMon knock sensor loom (see below for additional sensor & loom)
    Quality Headphones
  4. Gizzmo KMon Knock Monitor & Analysis Software CD
  5. 1 USB2 Cable
  6. 0V to 4.5V analog outputs per channel for analogous recording to external hardware e.g. analog inputs for Controllers, ECU’s, Dyno’s, Datalogging, etc
Group Buy: Gizzmo Boost Controllers - US & Canada Only TunerTools Tuner Tools 0 Feb 24th, 2008 02:56 PM
Tuner Tools & Gizzmo Electronics TunerTools Tuner Tools 0 Feb 24th, 2008 09:44 AM
MINI tire pressure monitoring system Adrian Wheels, Tyres & Brakes 7 Dec 4th, 2004 03:38 PM
