Engine stop button gets stuck down - MINI Cooper Forum
Welcome New Members New members, please introduce yourself here. Tell us a bit about you and your Mini.
post #1 of 7 (permalink) Old Jan 5th, 2014, 02:15 PM Thread Starter
Local Time: 09:12 PM
I have a Mini Cooper Automatic, it is 3 years old and I have had it since new.
I do not use the car very often, so to date it has done less than 3,000 miles. Yesterday after returning from a 2 weeks vacation, I drove to a supermarket to restock our food supplies, but when I came to press the stop button, it had jammed down, so I couldn't turn the engine off!.
I called my local Mini Dealership, but they were not very helpful, so I drove home to get my husband to drive his Mercedes, to get supplies.
The engine had now been running for 30 minutes, it was raining very hard and on leaving the car I slammed the drivers door.
On leaving our house before getting into the Mercedes, I retried the stop button in the Mini and it worked, hurrah!.
Is this a major problem with automatic Minis?, should I get the button replaced, can anyone advise me, before the dealership charge me for changing things that perhaps do not need to be changed. HELP.
dodiedon is offline
post #2 of 7 (permalink) Old Jan 5th, 2014, 03:14 PM
Hi ya
If you have a maplins or similar near you ask them for a spray switch cleaner or isopropyl alcohol and a can of dry air for cleaning key boards with.
With ignition off and key gob out give it a spray down the sides if the button. Try to keep the cleaner away from the trim or it my damage it. I used a load of micro fiber cloths and old tee shirt
Work the switch a few time and blow it out with air the repeat it a few time.
It should fix it.
Hope this helps
marque is offline
post #3 of 7 (permalink) Old Jan 5th, 2014, 04:49 PM
Quoted: 39 Post(s)
Yep, that's the stuff - also called Contact Cleaner and it's worth having a can of it around the house. For example, it rejuvenates tired remote control buttons that may have suffered a drink spilt on them. A Maplins or electronic store isn't really necessary - a good hardware store, a larger DIY store or probably Halfords will carry it.
Angib is offline
post #4 of 7 (permalink) Old Jan 6th, 2014, 01:29 PM Thread Starter
Thanks a lot guys will get some from Halfords, will this stop the button sticking down, the dealers said it probably the spring that's failing i.e. a new switch, but will try the spray and see if it stops it from sticking on.
What about the noise from the rear brakes, is it common with Mini's being out for 2 weeks in storms for them to rust up a bit?, or will it just stop with a bit of wear?.
Thanks for your help.
dodiedon is offline
post #5 of 7 (permalink) Old Jan 6th, 2014, 02:28 PM
Quoted: 39 Post(s)
Noisy brakes are absolutely normal, if you haven't used the car for a day or two. Just surface rust on the discs, which you can even see through the wheel spokes.
They should go quiet as soon as you do some braking - if you are a very gentle driver, that can take a while, but one stop at motorway speeds will do it. If the noise persists after some braking, it's something else.
Angib is offline
post #6 of 7 (permalink) Old Jan 7th, 2014, 07:03 PM Thread Starter
Sticking off button
I am afraid its getting worse. Today I had to move my car on our driveway, it started great but again it wouldn't stop, will be going to Halfords on Thursday to get a contact spray, but until then this is what happened.
As the engine could not be turned off, my husband came out to the car with a small very thin screwdriver, he pushed this down the side of the button and the button popped up turning the engine off.
Of course we cannot go on doing this every time I use the car, so tried to get a new switch. Now comes the crunch!. The switch cannot be purchased on its own, it is part of a complete switch coded system. My Mini Dealer has quoted me over 300 to replace and re-code the new switch.
As the car has still only done 2,893 miles I think BMW Warranty should pay for it, the Dealership is trying to establish that. I also have extended Warranty with Warranty Direct, apparently this coded switch is not covered by the policy, one wonders what is covered?.
So here I am presumably I must get this done before the MOT is due in April, so has anybody heard of anything like it?, the Dealership said it was a first for them.
dodiedon is offline
post #7 of 7 (permalink) Old Jan 8th, 2014, 12:13 AM
Hi ya
I think your warrantee should cover it.
It is a problem with bmw range they do fail on the bmw range with a start push button and the same with the minis.
It normally either jams like your one has or when you push the fob in it will not start the car
If you have another dealer near you try them, they may do it under warrantee see what they say.
If that fails you need to speak to mini uk, but make shore you mention that to the Dealer but nicely in conversation :-)
I do know someone who had problems with there mini warrantee work he used the mini twitter feed That got a response :-)
Hope it helps you
marque is offline
Engine turne off while at stop light Courtcm Second Generation Faults & Fixes 2 Dec 20th, 2013 11:22 AM
2006 S Engine for a Non S 2002 mikeroth First Generation MINI Tuning 1 Dec 10th, 2013 10:59 AM
Mini Cooper 2002 - Fit engine Start Button lucass_247 First Generation MINI Cooper 0 Dec 29th, 2012 01:57 PM
Mini Cooper 2002 - Fit engine Start Button lucass_247 First Generation Interior & Ice 0 Dec 29th, 2012 01:56 PM
BMW three-cylinder MINI engine revealed mab01uk MINI in the Media 1 Oct 9th, 2012 11:42 PM
