2003 mini cooper s engine ticking noise when idling. - MINI Cooper Forum
Welcome New Members New members, please introduce yourself here. Tell us a bit about you and your Mini.
post #1 of 3 (permalink) Old Feb 14th, 2014, 02:29 PM Thread Starter
Local Time: 09:58 PM
United-States 2003 mini cooper s engine ticking noise when idling.
Hi all! I've been the proud owner of a 2003 Mini Cooper S for a year now. It's been a great vehicle until recently. I start my baby car, as I call it, and when the car gets up to temp, it make a loud ticking noise. It doesn't go away when you step on the clutch. It goes away when it reaches about 1800 to 2000 rpms. Just had it in to replace the spark plugs and the oil filter housing, also something to do with a pcv bolt. What could be the problem? I would like to have my baby car for a long time and I need to figure out what my options might be. Any help would be greatly appreciated! Thanks!
tlw3333 is offline
post #2 of 3 (permalink) Old Feb 14th, 2014, 03:03 PM
Local Time: 03:58 AM
Hi ya
How many miles you have on your car and has it any mods
It could be a few things
Check you harmonic crank pulley they fail and make the same sound as your describing and my one sounded like the clutch was gone.
But I would say it sounds like you clutch is failing it could be the dual mass flywheel rattling or may be a clutch plate, pressure plate or thrust bearing failing
Hope this help
marque is offline
post #3 of 3 (permalink) Old Feb 14th, 2014, 03:09 PM Thread Starter
United-States Thanks
My car has 119,000 miles on it. So it could be the clutch? It doesn't affect the noise that the car is making. I push in the clutch and the noise does not go away. The car starts fine and there is no noise right away, but when the car warms up a bit, then it starts sounding chunky like a diesel engine. You really think it would be related to the clutch? I will check it out and see. I didn't mention earlier, but there is the distinct smell of gas when it is idling and even when driving. Could this have anything to do with my problem? No mods that I know of.
tlw3333 is offline
Tags: , ,
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 04:15 PM
Please help! My car won't start & makes clicking noise... 2003 Mini Cooper Tyna General Discussion 3 Feb 1st, 2014 10:38 PM
Oil consumption Mini Cooper s N18 engine peterhellawell Maintenance & MINI Care 1 Jan 24th, 2013 10:11 PM
