2003 cooper s no spark on cylinder 2 HELP - MINI Cooper Forum
Welcome New Members New members, please introduce yourself here. Tell us a bit about you and your Mini.
post #1 of 7 (permalink) Old Apr 26th, 2014, 03:56 AM Thread Starter
Local Time: 08:34 PM
I recently had a p0304 (engine misfire detected) code come up on my 2003 mini cooper s and have read almost every thread I could find. I did notice the same corrosion problems on the poles and replaced the coil, changed the plugs and wires. Now I have p0302 code come up and I have no spark on cylinder 2. I used a timing light on each plug wire and cranked the engine and 1,3,4 all have spark but 2 does not. I place the old coil back on and same p0302 code. I have reset the ecu and still no luck. Is it possible the "faulty coil" could damage the ecu. I am thinking it is the ecu but any suggestions???? HELP
Thanks in advance
sideshowbob111 is offline
post #2 of 7 (permalink) Old Apr 26th, 2014, 05:51 AM
Local Time: 07:34 AM
Quoted: 146 Post(s)
Australia Male
Garage
Your new coils may be OK but have you checked the new plug lead ? it could be a faulty plug lead.
Milpol is offline
post #3 of 7 (permalink) Old Apr 26th, 2014, 11:26 AM Thread Starter
I swapped different plug wires and still do not get any spark after the coil. By using a timing light on the spark plug wire you can see if you are getting a spark when you try to crank the engine. Changing plug wires still had no effect. 1,3,4 all have spark just not number 2.
post #4 of 7 (permalink) Old Apr 26th, 2014, 02:18 PM
Hi ya
I take it you have tried different set of spark plugs or swap your plugs around.
If the spark plug is not discharging the charge from the coil pack ie failed or fouled pug you will not get and indication on your timing light.
Hope this helps
marque is offline
post #5 of 7 (permalink) Old Apr 26th, 2014, 05:20 PM Thread Starter
Thanks for the tip but, you can check the spark on the wire without it being connected to a spark plug with a timing light. Just disconnect the wire from the plug and connect the light to the wire. I tested this on each cylinder and it works on all without a plug. any other ideas?
post #6 of 7 (permalink) Old Apr 26th, 2014, 06:17 PM Thread Starter
Marque, I want to thank you for your post. I was really confused why the timing light worked on 3 of 4 cylinders not attached to plugs. I moved the plugs from 1 to 2 and the problem did move!!!!!! The plug were changed recently that is why I ruled out the plugs. (stupid on my part, I know better) New plugs and reset the computer and she is running great. Thanks for the help.
post #7 of 7 (permalink) Old Apr 26th, 2014, 06:27 PM
Hi ya
No problem glad it's sorted :-)
marque is offline
2003 Mini Cooper s. Misfire above 3000 rpm Andrewthesabin First Generation Faults & Fixes 10 Feb 19th, 2015 03:54 AM
Hi from 2003, Cooper S GTT 220 conversion Newbie! GAJA71 Welcome New Members 6 Dec 7th, 2013 07:29 AM
2003 Cooper vs Cooper D minioll MINI Cooper Diesel 5 Feb 1st, 2013 02:41 PM
