Can I fit 195/55 on my R15 wheels? - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
  #16 (permalink)
Old Oct 16th, 2005, 01:14 AM
xtremepsionic's Avatar
Vroom!
Local Time: 02:00 PM
Canada Male View xtremepsionic's Chili Red & White 1st Gen MINI Cooper Profile
The main reason to stay within +/-3% is to have accurate speedometer and mileage readings. The slighty smaller 195/55/15 will be just fine. It will lower your car very slightly, and give you slightly better gearing advantage.
The difference is so small I doubt you'll feel it, what you'll feel is the difference in grip with the new tires (probably quite a bit more!) and stiffer sidewall, thus more positive handling feel.
I've searched a lot on this topic and it does not seem like the dealer will be able to help you with speedometer calibration, you can call and check however. I wouldn't worry about it too much, 195/55/15 is close enough.
  #17 (permalink)
Old Oct 16th, 2005, 01:45 AM
Deadliner's Avatar
Local Time: 11:00 PM
Greece Male View Deadliner's Chili Red & White 1st Gen MINI Cooper Profile
Thanks a lot once again for the useful reply!
  #18 (permalink)
Old Jan 23rd, 2006, 11:20 PM
Local Time: 12:00 AM
Greece Male
hello deadliner
did you got your new pair of tyres?
will you give us your feedback?
thanks
nik66
  #19 (permalink)
Old Jan 24th, 2006, 07:49 AM
Deadliner's Avatar
Hello,
yes I did fit new tyres, I think I wrote about it in another post about tyres so I forgot about this one, sorry
I went for the Dunlop SP Sport 02, 195/60/15 which proved to be breat tyres (at least compared to the OEM ones). They fitted just fine and they don't seem like they're too wide for this rim. They just look ok and in place. The tyres now look wider (there is noticeable difference), although I guess they would look even better on a wider rim.
As for the height, 195/60 is slightly higher but I guess that's ok, the car goes great. I did notice some difference while driving, compared to the old tyres but I think it's because of the new tyres being *new* and wider. For example, I noticed that the steering response got kind of quicker.
So, I can't tell about the dimension of 195/55 (as stated in the thread's title), but I can tell you that the width of the tyre is ok and that the 195/60 run fine!
225/50 R15 - Will they fit? Boris MINI in Motorsport 2 May 26th, 2004 03:36 PM
Anyone fitted 195/55 15 or 195/6015 to std 15" wheels Solwood Wheels, Tyres & Brakes 25 Sep 3rd, 2003 06:51 PM
Cooper S with 15x7 wheels with 195/60/15 ficcion First Generation MINI Cooper S 3 Oct 15th, 2002 03:34 PM
