moving away from standard run flats - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Oct 17th, 2005, 08:04 AM
pkman's Avatar
Local Time: 08:10 AM
After purchasing my Mini 2 months ago...I am not entirely happy with the run flats they do...doesnt feel as nice as the Yokohama AVS sport on my old Civic
Just wondering did any of u guys swapped from run flats to aftermarket tires afterwards and if so...wot happens to the on board computer? cos it registers with run flats..i.e if there is a puncture the car will recognise it...with aftermarket tires..will the car just ignore this functionality?
Any normal garage can do the tire swap from run flats to normal tires or do u need a specialised garage?
I have 16" wheels on 195 tires...do anyone do the jump to 205 or is it not possible?
Also is a spare tire needed once u go away fromt he run flats?
Cheers...
Old Oct 17th, 2005, 09:01 AM
Paul's Avatar
MINI2 No.1
Local Time: 07:10 AM
England Male
Loads of people have done this, and there's lots of information on it in this forum.
Try the Tyre Statistics as a start point:
Old Oct 17th, 2005, 09:02 AM
Quickbrick's Avatar
Local Time: 05:10 PM
Australia Male View Quickbrick's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
Hi pkman,
I can't answer the question about run-flats versus standard tyres - I'm thinking of doing it too, so i will watch for advice from others on this thread.
I can answer a couple of your other questions though....
- Flat-tyre indictor works using the same sensor as the ABS system. This works by noticing that one wheel is rotating at a different speed to the others. Obviously this system also takes into account whether you are steering or braking when taking info from the 4 sensors - otherwise the flat-tyre indicator would light-up when every time you spin the tyres or invoke the ABS.
- I believe most people who switch to non-runflats carry one of those puncture repair cans. I have also seen some pretty cool spare-tyre mounts some people have fitted here on MINI2, though I suppose it depends how much you use your boot, as once you put a spare in there you aint got one anymore ( a boot that is, not a spare).
Hope this helps,
Gregg
QuickBrick
Old Oct 17th, 2005, 10:32 AM
pkman's Avatar
thx - had a look.
Does this mean I can fit 205/50/16 tires onto my original Mini 16" wheels??
Mixing Run Flats with non Run Flats Aberdeen Al Wheels, Tyres & Brakes 3 Feb 2nd, 2007 03:38 PM
Is there a noticable ride difference between run flats and standard tyres? dazotron Wheels, Tyres & Brakes 7 Jan 1st, 2007 01:52 PM
Run flats versus non-run flats tceditor Wheels, Tyres & Brakes 10 Apr 26th, 2006 09:49 AM
Standard Performance Run Flats (17") D_Nyholm Wheels, Tyres & Brakes 2 Jun 18th, 2005 02:53 PM
Replacing run flats with non run flats? minifrog Wheels, Tyres & Brakes 2 Oct 24th, 2003 04:14 AM
