| Thanks MINIAC, More questions if you don't mind.. If I understand correctly, ET42 will push the wheels outwards by 8mm compared to the ET50s? Won't the centers of the tread be off enough to change handling a bit?? What about bearing wear? Thanks muchly for your sage advice (I researched using your FAQs) |
| Voodoo ... Your understanding is correct ... as the offset gets lower, the wheels move outwards. The new Aftermarket Wheel Gallery can be searched by offset: http://www.mini2.com/forum/showpost....51&postcount=2 The lowest offset in the gallery is ET35. Almost one-third of the over 80 cars in the gallery have offsets below 42mm ![]() For a stock size tire, you should have no concerns regarding any wheel which shows up on the Tire Rack configurator for the MINI. |
| Standard wheels offset | Juicysteak | Wheels, Tyres & Brakes | 2 | Aug 16th, 2007 06:11 PM |
| Wheels and Offset: There are no stupid Qs | JohnnyConvoluted | Wheels, Tyres & Brakes | 14 | May 19th, 2006 02:14 AM |
| HELP - 17 inch Wheels with 38 offset??? | CoolJamJar | Wheels, Tyres & Brakes | 2 | Apr 13th, 2006 12:27 PM |
| Advice before I order (Wheel size and tyre offset) | Spoony | Wheels, Tyres & Brakes | 2 | Jul 17th, 2005 09:14 PM |
| Does the wheel offset change if you change the width of your wheels? | Root Ginger | Wheels, Tyres & Brakes | 6 | Feb 23rd, 2005 10:22 AM |
