Rims and tyres - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Oct 22nd, 2005, 04:40 AM
mini one only's Avatar
Local Time: 03:10 PM
Malaysia
Rims and tyres
For PW ONE
What rim or tyres are suitable? Just for normal ride to be remapped soon.
Please comment on
a) 16" or 17"
b) oz superlaggera silver or oz superturismo GT
c) x40 or 45
d) weight of the oz rims
e) weight of the 15" MINI alloy rims
Thanks.
Old Oct 22nd, 2005, 09:55 PM
MINNOW's Avatar
Obsessive Not Compulsive
Local Time: 12:10 AM
Canada Male
a) 16" are better than 17" overall in my opinion, lighter weight typically, slighter higher profile tire fitting for better ride, wheels cheaper to buy, tires cheaper to buy.
b) Superleggara are lighter than 'turismo and easier to clean.
c) ET45 is same as stock and therefore preferable.
d) Not sure on the weight of the OZ 16 & 17's, but the 15" Superleggaras are only 10.4 lbs.
e) The 7-hole wheels are the best OEM choice and only 12 lbs each - fit some 195/55R15 performance tires on these and you will have an excellent cost-effective setup. The 8-spoke wheels are heavier at 15.2 lbs. each.
If available in your area the Konig Heliums in 15" are a good choice in the 10 lb. range and inexpensive.
For a MINI One weight is the enemy - go as lightweight as possible.
Old Oct 24th, 2005, 10:37 AM
Malaysia
Thanks , MINNOW!
Any idea what is the weight of R93 that came with the ONE?
Old Oct 24th, 2005, 04:16 PM
MINI2 newcomer
United States Male
Details of OEM wheels are given here: http://www.mini2.com/forum/faq.php?faq=faq_wheels_tyres.
R93 5-spoke Rocket ET45 14.8lb (6.7kg) [silver, white]
mmalc
Old Oct 24th, 2005, 05:55 PM
Malaysia
mmalc, thanks!
I wonder if its ok to replace the R93 ( 6.7kg) to the Superturismo 17" ( 9.4kg) ????
Standard tyres CAN be used on MINI rims space_cadet Wheels, Tyres & Brakes 16 Jun 29th, 2011 06:20 PM
205 tyres on 7.5 rims? MINI_Chris Wheels, Tyres & Brakes 3 Jan 22nd, 2007 03:38 PM
About tyres, sizes and rims J.a.y Wheels, Tyres & Brakes 1 Aug 24th, 2006 01:27 PM
Nonrunflat tyres on runflat rims seight Wheels, Tyres & Brakes 3 Sep 5th, 2005 07:11 AM
What 16 inch rims will take normal tyres? Targa First Generation MINI Tuning 7 Jul 16th, 2002 07:12 AM
