| They wear really well. The ride is outstanding compared to rf. They are great at ploughing through deep standing water. The grip in the dry is good . They slide nicely, not too snatchy- easy to control. The grip in the wet is bad on roundabouts or any tight turn, otherwise it feels stable. I have 220ish hp, and drive enthusiastically I wouldnt have these again- wished i gone for eagle F1's. Under normal driving they are fantastic + great value |
| I have a Cooper. I am on my second set of the 512's. Get about 20K miles per set, rotate front to back every 5K miles. I went with the 195/55-15, which I like a lot more than the OEM Conti 175/65-15. |
| had falkens on last 3 cars now love them had the 205 17" which were great but the 215 17" were even better stuck like **** too the road will be having falkens when the 18" go on the new one once the winter is out off the way front lasted 25000 on last one rears 40,000 ish |
| The rears on mine would probably of lasted longer if I hadn't of got Eibachs. The rears look fine at first, but the inside edge is preety low due to the camber. As said before done 18k on the first set of fronts (on a cooper) and 9k now on my second set with the S. Assuming I get another 9k out of the fronts (which I doubt) then I'm changing all 4... ...want Pirelli P Zero's or Eagle F1's next. P Zero's are looking like my favorite. ![]() |
| Wheel Balance over the long term.. What do you think of this? | Voodoo | Wheels, Tyres & Brakes | 10 | Oct 12th, 2005 10:38 AM |
| Long-term Test Drive | huntmdwn | General Discussion | 6 | Apr 7th, 2005 01:06 AM |
| Long term use: How is your leatherette holding up? | splits | First Generation Interior & Ice | 15 | Mar 9th, 2004 10:19 AM |
| Autoweek Long Term Mcs | visionary | General Discussion | 0 | Apr 26th, 2003 08:07 AM |
| mini long term | bonvec | First Generation Faults & Fixes | 6 | Feb 19th, 2003 09:58 PM |
