Tyre question - 215/45/17 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Nov 7th, 2005, 09:35 PM
Local Time: 08:10 AM
Hey all,
Been looking in the FAQ section and in there it says that 215/45/17 are ok for mini alloys. What is the difference between 205/45/17 and 215/45/17???
Sorry for the noobism!
Old Nov 7th, 2005, 09:49 PM
JohnP's Avatar
Local Time: 07:10 AM
They're around 10mm wider and ( because the "45" describes the height of the sidewall as a percentage of the tread width) fractionally taller in the sidewalls than the 205's.
Old Nov 7th, 2005, 09:51 PM
so they still fit ok, ist there any disadvantage or advantage to this? I bought a set of 4 from ebay for £210, ZE-512 falkens.
Old Nov 7th, 2005, 10:08 PM
JohnP's Avatar
I've never actually seen it done myself but in theory, there shouldn't be a problem.
The extra width should give a little more grip and the extra sidewall height will make the ride fractionally softer - if you're changing from run flats, make that MUCH softer..!
You had a good deal on the Falkens, so go for it...
Old Nov 7th, 2005, 10:23 PM
john thanks for the replys - well i hope it is ok! would be an expensive mistake if not!
Is any one else here running 215s?
Old Nov 7th, 2005, 10:31 PM
tnoy66's Avatar
POP..POPPOP..POP
England Male View tnoy66's Pepper White & Black 1st Gen MINI Cooper S Profile View tnoy66's Classified Ads
There's quite a few running that size tyre:
Tyre Statistics
Scroll down to the 17" tyres and then scroll down though that section
Old Nov 7th, 2005, 10:45 PM
Tyre Statistics
oh right cool,
well thanks all thats made me feel better. my alloys are off to get powder coated gloss black tomo
Old Nov 7th, 2005, 10:48 PM
bd394's Avatar
Local Time: 02:10 AM
United States View bd394's Solid Black & Body Color 1st Gen MINI Cooper S Profile
Hey all,
It will make your gearing slightly taller and affect your speedometer and odometer somewhat.
2003 Solid Black MCS All options (except Nav and PDC), Milltek cat-back, red/white tailights, Whalen knob, Osram Silverstar high beam, 16" Dunlop Winter Sport M3
Old Nov 8th, 2005, 12:59 AM
EBMCS03's Avatar
M5 Extraordinare!
Send a message via ICQ to EBMCS03 Send a message via AIM to EBMCS03 Send a message via MSN to EBMCS03 Send a message via Yahoo to EBMCS03
Local Time: 12:10 AM
United States Male View EBMCS03's Electric Blue & White 1st Gen MINI Cooper S Profile
It'll be off by soooo little its negligible.
Stock 204/45/16 has a diameter of 24.26 inches going to 215/45/17 will make it 24.62 inches... and affecting the speedo by 0.95mph. MINI OEM tires and wheel combo itself vary by more than that... its still well within tolerance.
http://www.mini2.com/forum/faq.php?f...heel_tire_tech
Scroll to the section "What should be considered in choosing a wheel and tire package?"
I too plan on going to 215/45/17 when i'm due for tires... I want to go with 225s but its a little more risky as some people report rubbing on the inner shocks... but some dont... *shrugs*
EB/W MCS Arrived (3/26/03) Premium & Sports Package, Lapis Blue Leather, Harmon Kardon, PDC, Tint, Aux Input, X-Pel Clearbra *SOLD* 4/25/06
Old Nov 9th, 2005, 09:13 PM
SteveM3's Avatar
Just make sure your alloys are OEM or near enough the same offset of 50mm. 215/45-17
will rub the wheel arches with some aftermarket alloys like mine of 40mm offset. You
probably didn't need to know this but I am looking for my 1,000 post .
215/35/18 Tyre Choices danb Wheels, Tyres & Brakes 24 Aug 20th, 2007 07:03 PM
215/45/17 Eagle F1 Tyre Pressures Sweeney Wheels, Tyres & Brakes 7 Jun 15th, 2007 12:51 PM
215/40ZR17 Tyre pressure help minirog Wheels, Tyres & Brakes 5 Jul 19th, 2006 10:31 AM
Tyre Pressure for 215/45/17 pubert Wheels, Tyres & Brakes 9 Jun 28th, 2006 11:22 PM
215/35/18 tyre pressures? CWaldie Wheels, Tyres & Brakes 5 Feb 26th, 2006 04:21 PM
