| Hi, Not sure about the exact weight of that combo but they will be fairly light, your can probably find out the weight of the wheel and the tyre separatly to get an idea of how heavy the combo will be. The offset is on the wider side, but it will have good caliper clearance if you wanted a BBK later. The tyres are slightly off on the size (normally 205/45 or 215/40) so your gearing will be lower, which will mean that you will accelerate faster. Which is more important in reality than top speed. Andrey |
| Yeh swap em for 45 profile after they are worn, ride quality wont be too bad if you have not had it lowered, although it will be more bumpyer than the 16s on runflats. Im pretty sure that 17" combo will be similar weight to the mini 16s as the leggras are a very light wheels to start with so you wont find your car any slower!. 2001 cooper (sold) ![]() 1995 Supra RZ-S TT auto in white. |
| Hi, 17" superleggas weigh 15.2 lbs, 16" x-lites weigh 17.6 lbs so they are very light.Goodyear Eagle GSD3 are great tyres,arguably the best for the Mini. This is the combo i intend to fit shortly. £600 is a good price,who is doing that deal? |
| I've got 17" Oz Superturismos with 205/40's on with no real problems.. the 40mm profile gives the wheel edge a bit of protection actually. Mine is a 45mm offset so I have no real problems, 18" OZ SuperL's I believe have to be bought in a 38mm offset otherwise they won't fit IIRC ![]() If you do a search for Oz Superleggeras on here there is a lot of info ------> I have a Gen1 Works S and I'm proud of it <------ |
| Superleggeras | SteveM3 | Wheels, Tyres & Brakes | 2 | May 28th, 2007 06:53 PM |
| My new 18" OZ Superleggeras! | Ibb | Wheels, Tyres & Brakes | 35 | Mar 4th, 2005 08:16 PM |
| Superleggeras | Darren S | Wheels, Tyres & Brakes | 7 | Nov 14th, 2003 12:32 PM |
| Q about 17 OZ Superleggeras | MrMow | Wheels, Tyres & Brakes | 5 | Dec 28th, 2002 03:09 AM |
