| Brake pad and disc costs My car is at 48,000 miles. The last service in July didn't pick up my brake pads being low. I was half expecting to have to replace them about now. On Friday, I heard grinding from the rear brakes. I'm assuming that means that the entire pad is gone and I've just knackered my discs as well. The brake warning indicator didn't come on, and there was no audible indication before the pads wore out. Is this a fault? How much am I likely to be looking at for four new brake pads and two new rear discs (assuming they're scored), all fitted, from a Mini dealer? Any advice? Thanks |
| Thanks for the suggestions, guys. Since I need the car to get to work, I'm looking at getting everything done at a garage. I was just wondering what a ballpark figure might be at a Mini dealership, and the "Kwik-fits" of this world. I don't have the knowledge, time, or equipment to do the job myself. Thanks |
| yeah bmw are expensive (quote 200 gbp) so im off to lohen next week for new greenstuff pads minitorque.com, the site for mini performance, drag racing track days & time attack its all change for the S, to be revealed soon |
Brake Replacement Help?I admit I am new to this and trying to get a sense of the etiquette of posting. I have searched numerous postings to find something similar to my situation. This is the closest I could find. I have a 2002 Mini Cooper S with a little over 40,000 miles on it. I went to drive it on Friday and heard, for the first time, metal on metal sound when I applied the brakes. I promptly turned around and scheduled service on my car. I anticipated needing new pads. The dealership is now telling me that it is "policy" that whenever there is a brake work it is automatic that pads and rotors are replaced. They don't just do pads. I was told it is due to the "soft compact rotor design". I find this very hard to believe that you always have to change out the rotors with the pads. Help???? Is the dealership trying to "take me" or is it true that it is 'policy' to change the rotors out with the brakes? |
| I just replaced my rear brake pads without doing the rotors/disks. 'Course, I did it myself so no tech can force me to do the rotor change. I will however be replacing the front brake rotors when I do the brake pads on that end as they are well below tolerance. Basically, from what I've heard about BMW brakes, the stock rotors are made of a far softer metal then other vehicles have. Hence the superior braking of the Mini. If you think the tech is taking you for a ride, check the "lip" on the rotor when the wheel is off. On mine I can see a few millimeter step on the front set. (where the shinny part hits the rusty/dirty part) Regards, Drej |
| I just replaced front rotors (discs) with DBA slotted ones and all four pads (front and rear) with EBC Greenstuff, two Mini dealers quoted $900 for parts and labour for OEM Replacements. I sourced the parts elsewhere and paid our local BMW Dealer to fit the parts, and ended up costing $600 including brake fluid change, and the braking is much improved now that everything has bedded in properly, there was a fairly dcent lip on the front rotors (just over 1mm I'd say) where the pads had worn the rotor down, and there was very little wear on the rear rotor (so we just changed the pads - didn't even bother getting them machined) Compared to other cars, I'd say the rotors are quite a bit softer, but it really does pay to have a look around and see what non Mini dealers can do for you. |
| Hi all, Just thought I would comment on this thread as I have just had a call from bmw saying that I need new pads fr + re and new front discs. My MCS is 54 plate and done 30000 miles.....is this normal or shall I get a second opinion from a non-bmw garage??? I have also been quoted circa 300 squid for the job, which I promtly turned down. I have replaced brake pads / discs on other car before but not my MCS, is there anybody with tips on how to do it? and mainly tips on where to get the parts from?? I am also concerned that I get the right parts seeing asthough I will not be getting them from bmw. Any help would be great Thanks Tom 0 days to go....lets drive!!! CAN YOU TELL WHAT IT IS YET!!!! |
| Disc and pad replacement | Peartreeproductions | Wheels, Tyres & Brakes | 0 | Apr 28th, 2007 09:12 PM |
| Brake Disc and Pad recommendations? | jb4845 | Australia | 4 | Dec 7th, 2006 09:31 AM |
| UK Dealer brake pad costs? | Rayman | Wheels, Tyres & Brakes | 6 | Mar 11th, 2006 08:12 AM |
| brake pad help | Haggi | Wheels, Tyres & Brakes | 6 | Dec 13th, 2005 09:26 PM |
| Being charged £235 for disc and pad replacement. Is this right? | Tall bloke | General Discussion | 1 | May 28th, 2004 04:06 PM |
