Wipac
Old Jan 31st, 2006, 08:57 PM   #1
Peartreeproductions
Mini spanker
Peartreeproductions's Avatar
Local Time: 01:51 AM
Unhappy Runflat repairs - should I be worried
I had a runflat repaired a few months ago and recently found a nail in my other rear tyre. After phoning up the garage that I was sure had fixed my first puncture, they said that runflats couldnt be fixed blah blah blah. They said that the tyre had to be drilled through and that it weakened the tyre.
Firstly I am worried about safety. I know that I had the first runflat fixed by a 'reputable' tyre shop but should I be worried? Secondly where can I get the second repaired if it is safe to do so? I have tried Kwik-fit and Holburn with no success.
Lastly why have runflats if they cannot be repaired - surely a can of Tyreweld and non-runflats should achieve the same result?
United Kingdom View Peartreeproductions's Pure Silver & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Jan 31st, 2006, 08:59 PM   #2 (permalink)
minibbb
Online
BMW recommend no repairs on run flats, thats why I spent £170 buying a new one! Apparently it can affect your insurance but that could just be a rumour
Old Jan 31st, 2006, 09:01 PM   #3 (permalink)
:: Jon ::
:: Jon ::'s Avatar
ive had 3 repairs altogether on 3 of my tyres over the last few yrs one being around 6 months ago and never had any problem with getting it fixed. even BMW will do it at a higher price
costs around £16
UNLESS
its in the side wall then it cant be repaired
EMPTY SPACE NEEDS FILLING....
but it has to be something that wont get me banned
Old Jan 31st, 2006, 09:04 PM   #4 (permalink)
:: Jon ::
:: Jon ::'s Avatar
BMW will repair them. got my first one done by them.
Old Jan 31st, 2006, 09:07 PM   #5 (permalink)
minibbb
Online
oh no they won't. Even the BMW manual says they do not recommend run flats should be repaired. You sure yours are runflats?
Old Jan 31st, 2006, 09:15 PM   #6 (permalink)
:: Jon ::
:: Jon ::'s Avatar
well nearly 4 years of buying runflats and having 3 repairs in these 4 years.. one by bmw, one by kwik fit & one by national tyres.... yes they do repair them.
Old Jan 31st, 2006, 09:16 PM   #7 (permalink)
:: Jon ::
:: Jon ::'s Avatar
if the tyre has been completely RUN-FLAT and damage has been caused to the side walls then no they cant be repaired. thats obvious but otherwise they can
Old Jan 31st, 2006, 09:20 PM   #8 (permalink)
:: Jon ::
:: Jon ::'s Avatar
just another person who has had a repair
http://www.mini2.com/forum/wheels-tyres-brakes/109050-runflats.html
Old Jan 31st, 2006, 09:54 PM   #9 (permalink)
Annette S
Just another showgirl
Annette S's Avatar
Local Time: 04:51 PM
costs around £16
UNLESS
That is sooo good to hear! I just replaced a tire after finding a nail in in a few months ago, happened over the weekend and spent almost $400 (yikes!!!) It made me sick thinking about having to do it again...and then yesterday I just spotted another nail in another one of my tires. So far the warning light hasn't come on, wonder if I should fix it now before it does....??? Or just leave it alone and start saving up in case BMW (over here) won't fix it...???
United States Female   Reply With Quote
Old Jan 31st, 2006, 10:02 PM   #10 (permalink)
:: Jon ::
:: Jon ::'s Avatar
go and see if they will fix it or go to any tyre shop and let them have a look. as long as the nail
is around the same area as this within the tread
then you wont have or shouldnt have any problem getting it repaired
Old Jan 31st, 2006, 10:39 PM   #11 (permalink)
smc
smcc
Local Time: 09:51 AM
I had my runflat repair two times so far so good - done 10,000kilometers without problem.
Singapore Male   Reply With Quote
Old Feb 1st, 2006, 04:33 AM   #12 (permalink)
Annette S
Annette S's Avatar
Electic Blue S Thanks for the advice
Thanks, Jonmorgan and SMC. Makes me wonder if my first tire had been fixable as well... Why do they even tell people that run flats are unrepairable if they actually are? I've been so tempted to change them all out to regular tires, but with an S, where do you put the spare.....???? Tempted to get a roof rack and throw it up there, now wouldn't THAT look attractive...!
Old Feb 1st, 2006, 07:05 AM   #13 (permalink)
k m s
Premier League
k m s's Avatar
Send a message via MSN to k m s
Repairs to run flats aren't recommended, as there may be internal damage that cannot be seen:
One area of particular interest is the question of repairs to Runflat Tyres. At the moment the majority of tyre manufacturers DO NOT recommend a Runflat tyre be repaired following operation at reduced pressure. When a standard tyre is punctured and runs at reduced or zero pressure it will suffer damage to the sidewall that will render it unfit for repair and re-use. This damage is easily spotted once the tyre is removed and is usually seen as a creasing to the inner liner of the tyre in the sidewall area. This creasing indicates that damage has occured to the internal construction of the tyre and further use could result in casing failure.
Due to its heavily reinforced sidewall construction a Runflat tyre will not exhibit these signs and there may be internal damage that cannot be seen. A Runflat tyre will undergo a great deal of stress while operating in a zero pressure situation and will therefore be subject to greater stresses than a standard tyre. The actual tyre does not carry the weight of the vehicle - it is the pneumatic effect of the air inside the tyre that carries the weight.
It is believed that the British Rubber Manufacturers Association (BRMA) are shortly due to make an official recommendation regarding repairs to Runflat tyres.
England Male View k m s's Hyper Blue & Dark Blue 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old Feb 1st, 2006, 08:01 AM   #14 (permalink)
emu_p
Now on my 3rd Mini !!!!
emu_p's Avatar
Local Time: 12:51 AM
My local tyre shop that has the contract for the BMW dealer I bought my s from refused to fit non run flat tyres to an alloy wheel that had been fitted with run flats from the factory something about the bead on a non run flat will not fit the rim profile correctly so therefore is not safe!
England Male View emu_p's Pepper White & Black 1st Gen MINI One Diesel Profile   Reply With Quote
Old Feb 1st, 2006, 04:37 PM   #15 (permalink)
Richy777
Richy777's Avatar
As long as the tyre has not got anydamage IE. runflat/soft and the repair is within the recomended area as set out by British Standards you should have no problem in getting / using a repaired tyre. I work for a large tye manufacture and this is there recomendations. BMW just playing safe as there is a high chance a runflat tyre might have ben run soft/flat tus damaging the side wall. But if is is a puncture that you have just spotted before the tyre has gone to soft you will most probally be ok. You can fit none runflat to runfalt rims no problem.
Richy...
Old Feb 1st, 2006, 04:46 PM   #16 (permalink)
:: Jon ::
:: Jon ::'s Avatar
for them to say they cant fit normal tyres to a rim that had a run flat on.. they are only saying that to get more money out of you.. as a lot of people have changed to normal tyres from run flats and just carry a can of tyre foam in the boot as its cheaper for the tyres..
Old Feb 1st, 2006, 07:01 PM   #17 (permalink)
holder
holder's Avatar
Interesting thread. I've just replaced two tyres with run flats as was told by my stealer and two tyre garages that run flats cannot be repaired. Also told that non run flats would not sit on my S-Spokes properly? Crooks.
United Kingdom View holder's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 1st, 2006, 07:42 PM   #18 (permalink)
:: Jon ::
:: Jon ::'s Avatar
here are a few people who have got rid of those run flats and replaced them with another type of tyre..
http://www.mini2.com/forum/showthrea...12#post2223112
Old Feb 1st, 2006, 11:03 PM   #19 (permalink)
klint
Ninja
klint's Avatar
I personally would ditch runfalts if they need repairing or have had repairs.
Think of them as a crash helmet, designed to be dropped once.
Isle of Man   Reply With Quote
Old Feb 2nd, 2006, 12:07 PM   #20 (permalink)
emu_p
emu_p's Avatar
Yep I also have s-spokes and they said the rim was not suitable for non run flat tyres!!
My runflat warning light was flashing but im not using runflat tyres??? fozworth Interior & Ice 3 Dec 24th, 2006 05:42 PM
non-runflat foam in a can puncture repairs Bezza Wheels, Tyres & Brakes 1 Apr 23rd, 2005 11:34 AM
repairs mrb MINI Cooper 1 Apr 2nd, 2005 09:41 AM
Repairs after repairs...anyone getting sick of it? n00b Faults & Fixes 75 Oct 15th, 2004 06:58 AM
worried now truane General Discussion 8 Feb 26th, 2004 09:51 AM
