Old Feb 4th, 2006, 05:39 PM   #1
BlackFerret
Here and There
BlackFerret's Avatar
Local Time: 01:32 PM
Send a message via MSN to BlackFerret
Uprated Brakes (changing)
i have just bought the EBC Brake pads, discs and a couple of bottles of AP Racing Brake fluid, oh and goodridge braided brake lines.
I have installed discs and pads couple of times before and bled loads of land rovers brake systems but from what i have read the minis resevoir also feeds the clutch
what is the easiest way of changing out the hoses (drain out the whole system then refill) or (let it go all over the shop while i change the hoses then try to swap out the fluid as i go)
i really don't want to get air into the system but is it possible to do this any other way!!!!
heeeeelp!
United Kingdom Male View BlackFerret's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 4th, 2006, 05:56 PM   #2 (permalink)
obehave
Mini Mod
obehave's Avatar
Local Time: 08:32 AM
heeeeelp!
I didn't have much problem when I changed mine out. I just made pluge from vacuum hose to cap the lines while I swapped out the lines. Kept the drip to a minimum. Lost maybe a 1/3rd of a cup.You'll get a drizzle when you take of the lines, that's the worst part and that's just what's in the line.
After that I bled the whole system and forgot about the clutch , did that later.
You should do that first. Ooops on me.
Luckily it didn't make a difference.
I usually get the leaky messy part done first to reduce any chance of getting brake fluid on my new pads or rotors. That's just me though.
Old Feb 4th, 2006, 06:03 PM   #3 (permalink)
BlackFerret
Here and There
ohhh thx i may do this!
still though do you get some poor soul to pour in the juice while you pump the pedal and try to get it through to all the system one-by-one? (as you go around)
surely the brake fluids will mix and make it less effective?
it may not be, correct me if i'm wrong
Old Feb 5th, 2006, 08:36 AM   #4 (permalink)
BlackFerret
Here and There
anyone?
Old Feb 5th, 2006, 12:58 PM   #5 (permalink)
DCM
Ding Dang Do !
DCM's Avatar
Local Time: 12:32 PM
Send a message via MSN to DCM
From the mini manual ive got it recommends to use a pressure bleeder, not sure if this is actually a requirement though as ive never done it myself.
United Kingdom Male View DCM's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 5th, 2006, 04:22 PM   #6 (permalink)
obehave
Mini Mod
obehave's Avatar
They're very nice but not cheap. Family labor is cheaper
BlackFerret:
The fluids don't really mix they stack up so the new pushes out the old. It's maybe 2-3 pedal pushes from when you see the old dark fluid leaving until it's all new fluid.
I have a clear drain tube that has a check ball at the end to keep air from being drawn back in.
The wife or daughter does the pedal pumping
Now here's a single guy story for you.
I used to mod Chevy pickup trucks and did most of the work alone. So I built a pedal pusher out of an old truck shock and some blocks of wood.
I'd pump the pedal and then wedge the shock in between my seat and the pedal then go crack the bleed valve,
Mother of invention eh
Old Feb 5th, 2006, 06:57 PM   #7 (permalink)
BlackFerret
Here and There
ROFL!!!!!
thx for the info mate!
i'll just pour it in then!
Old Feb 5th, 2006, 08:26 PM   #8 (permalink)
SteveM3
SteveM3's Avatar
Hope I am repeating what you already know but keep the brake fluid topped up all the time.
It was never good to get air in by letting the fluid go low in the reservoir but on modern cars
if you get air in the ABS unit it's a specialist job to get it out. I'm sure you won't though .
England Male View SteveM3's Electric Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 5th, 2006, 08:52 PM   #9 (permalink)
BlackFerret
Here and There
i shall draft in a squad of minions to watch that resevoir with the eyes of eagles.....
Old Feb 5th, 2006, 08:58 PM   #10 (permalink)
fireman01
60mpg
fireman01's Avatar
easy bleed
you can buy a cheap easy bleed kit,its a bottle you fill with fluid and connect to the reservoir it has another hose you connect to the spare wheel and this pushes the fluid through making it a one man operation
Old Feb 5th, 2006, 09:22 PM   #11 (permalink)
BlackFerret
Here and There
i've seen these my mate has one just thinking whether to go borrow it!
How long before I need brakes changing? old_buffer Maintenance & MINI Care 11 May 25th, 2006 11:53 PM
uprated gearbox ? bclinch MINI One 4 Feb 28th, 2006 05:25 PM
Rear brakes changing help required FONTAL Maintenance & MINI Care 1 Oct 29th, 2004 08:27 AM
Uprated cams? PW51CAR Engine & Drivetrain Tuning 0 Feb 12th, 2004 12:43 PM
