| MINI2 Regular Join Date: Nov 2005 Local Time: 03:27 PM
Offline | painting calipers I got some red paint special for calipers. Has anyone experience with painting(spray) the calipers? Can you give me some advice about how to. What can I spray and what not? |
| MINI2 Regular Join Date: Dec 2004 Location: Iowa Local Time: 08:27 AM
Offline | I painted my calipers red, too. However, I used a two part epoxy brush-on paint--not spray paint. I didn't take my calipers off to do it. You don't want to paint the pads or the rotors (obviously) and don't paint any screws/adjusters. If you're using spray, you probably want to remove the caliper, or tape everything up real good. Oh--keep a can of brake cleaner, a wire brush, and a rag handy. If you accidently paint something you shouldn't have (I got some on the rotor once), the brake cleaner will take it off when the paint's still wet. Be sure to clean everything before paint--the brakes will be very dirty. |
| MINI2 Regular Join Date: Mar 2005 Local Time: 06:27 AM
Offline | I painted my calipers yellow using the brush-on paint kit from G2. You'll want to really clean those calipers well before you start. If the calipers are dirty the paint will chip off or just not stick. Get a couple of cans of brake cleaner and a good brush. Scrub it is well as you can. Do the cleaning outside because the brake cleaner fumes are pretty toxic. It easier to remove the calipers to do the painting but many have painted without removal by using a lot of tape. If you do opt to remove the calipers, you'll probably also remove the brake pads. On the rear, this means you'll need a piston tool or a clamp to push the brake piston back in so you can replace the pads. You can probably not paint the parts of the caliper that are unseen. That includes the inside of the parts holding the pads and behind the rotors.You'll also want to avoid the caliper rods and rubber boots. Hope that helps! |
| Best Personal Regards Join Date: Dec 2004 Location: Ile de Vaux, France Local Time: 04:27 PM
Offline | My experience has been that caliper paint will work very well as long as you do not heat up the calipers. My rear ones. which rarely get hot are still nice and red. I painted my front ones twice with the serious caliper paint and they turned black after a couple of track sessions. so, if you do not ttrack your car, the paint route is good. |
| MCS what else is there? Join Date: Jan 2006 Location: Melbourne, VIC Local Time: 12:27 AM
Offline | About to attempt this myself, what kinda paint do you all recommend the calibre paint or normal metal paint? Also when you paint them you can put the wheel on straight away can't you? you don't have to wait for it to dry before putting the wheel on? PS: I won't drive it for a while! |
| | #6 (permalink) |
Offline | It needs to be high temperature paint. A two part paint (one that you have to mix together) will stick better/longer. I would recommend the brush on type--it's less messy. A paint that's advertised as caliper paint will meet these requirements, but may be more expensive than the exact same paint that's advertised as plain-old metal paint. You could put the wheel on right away if you really wanted to. I wouldn't recommend it. It'll be harder to inspect the calipers once they've dried. There might also be dirt on the wheels. Two jackstands and a floor jack will hold all four wheels off the ground overnight. |
| | #7 (permalink) |
Offline | Max thanks a heap for the link, very helpful. I am going to make sure i do it properly otherwise i can imagine it will look tacky. I bought top paint that with a shiney finish so hopefully it looks cool. If it all goes to sh*t i'll just repaint them silver. Thanks again |
| | #10 (permalink) |
| Got evidence? Join Date: Jan 2006 Location: Plymouth, MN Local Time: 08:27 AM
Offline | You made me laugh and spit out my coffee right into my keyboard! Thanks for the humor, I appreciate the chance to be a pill and have you not take it too seriously. |
| painting my calipers - pictures so far... | smit-one | Exterior | 13 | May 24th, 2007 11:33 PM |
| Painting my Calipers (different question than the usual) | MINI-LOVER | Wheels, Tyres & Brakes | 9 | Feb 13th, 2007 12:06 AM |
| Do I really new new calipers? | Grimaldi | Wheels, Tyres & Brakes | 3 | Jan 8th, 2007 03:42 PM |
| Painting my calipers today | tom2005 | Exterior | 15 | Jul 18th, 2006 10:30 PM |
| Question about painting calipers??? | ARitz | Exterior | 4 | May 24th, 2003 01:19 AM |
