Old Feb 13th, 2006, 02:02 PM   #1
KMK163
KMK163's Avatar
Local Time: 10:30 PM
Tyre Pressure!!!
Hello guys, i have a problem. I replaced my stock wheels and tires with 18 inches KAHNS 215/35/18. My problem is what air pressures shall i put in my tires as i lose pressure from them every 3-4 days. Of course is also the f**** roads that are fixing outside my house. Please give me a proper air pressure to insert in and bear in mind i dont do any tracks just cruising to work and maybe sometimes have a little drag but always in the highways no hard cornering. Thanks
Cyprus   Reply With Quote
Old Feb 13th, 2006, 02:23 PM   #2 (permalink)
bigcoyote
HOT Arizona
bigcoyote's Avatar
Local Time: 03:30 PM
United-States
Hey there,
My MCS has the stock 205/45/17 run flats - the factory PSI on the door sill says 31-38PSI ( depending on load ) - I would start somewhere in that area. Then...buy some chalk - run a wide stripe across your tires ( side to side on the tread ) - then drive a mile or so - maybe less -- look at the chalk stripes. If they are still visible in the center of the tread then you need MORE pressure -- if the stripe is visible on the edges of the tread you need LESS pressure. Repeat as needed to get the stripe to dissapear totally - then you have your correct pressure for that day / load / temp / etc....
As always - if you like "sprited" driving you may want a little more pressure - to prevent the tire from "rolling" inward during high G turns. And always follow the tire manufactures directions.
Good luck!!
United States Male View bigcoyote's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 13th, 2006, 10:40 PM   #3 (permalink)
xtremepsionic
Vroom!
xtremepsionic's Avatar
Local Time: 04:30 PM
Good tip on the chalk, however, don't forget that a warm tire will add another 1-4psi (depends on the tire and your driving) so this chalk test is best done when the tires are already warmed up.
the 31-38 psi pressure is for cold tires, for 18"s I wouldn't run anything less than 34psi. If you're losing pressure every 3-4 days you have a leak somewhere, normal tires might lose up to 1psi a week only.
Canada Male View xtremepsionic's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Feb 15th, 2006, 01:22 PM   #4 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Local Time: 11:30 PM
Tyre Pressure minimike7 Wheels, Tyres & Brakes 5 Jun 21st, 2007 11:03 PM
What tyre pressure is best? Jonny Muir Wheels, Tyres & Brakes 9 Jul 15th, 2006 08:10 AM
Tyre Pressure Help Please Pamster Wheels, Tyres & Brakes 3 Mar 6th, 2006 05:17 PM
What tyre pressure... Fullupo Wheels, Tyres & Brakes 5 Aug 20th, 2003 11:53 AM
Tyre Pressure DocT MINI Cooper S 0 Jul 17th, 2002 10:36 AM
