Adam's Polishes
Old Feb 15th, 2006, 02:20 PM   #1
Perm
Perm's Avatar
Local Time: 02:03 PM
Is my tracking out ?
Hi,
When I am driving on a level straight road I have to keep my steering wheel a few degrees to the right to keep the car going straight. Does that indicate my wheel tracking is out ?
Is getting the tracking straight a “easy” thing to fix, should I be able to trust a KwitFit type place or does it need to be booked in with MINI ?
Perm
Old Feb 15th, 2006, 04:03 PM   #2 (permalink)
Root Ginger
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
Get a laser alignment check done. I wouldn't recommend Kwik Fit really try someone like ATS or an independant garage.
This will indicate what's wrong. Tracking, camber, toe in and out etc. They will then put it all back to within spec for you and you get a nice print out to show you how it's all set.
It was acceptable in the 80's
Old Feb 16th, 2006, 02:39 AM   #3 (permalink)
robbo mcs
Track Addict
robbo mcs's Avatar
Local Time: 11:03 PM
Hi,
I know this sounds really obvious, but check your tyre pressures first to make sure they are all correct.
Robbo
Mods: Hartge kit, CAI, oil cooler, headers, cat & exhaust, bilstein coilovers, adjustable bars & camber plates, quaife diff, roll cage, seats, harnesses
GO MADDIE and SPARKY!
Australia View robbo mcs's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 16th, 2006, 02:58 AM   #4 (permalink)
Bilbo Baggins
Bilbo Baggins's Avatar
Local Time: 09:03 AM
Also, with the natural crown of the road it is normal for the car to pull a little to the left. If you can find an empty parking lot, that is reasonably level try it there and see if the pull is the same.
'06 MCS SB/S R84s(Dunlop 5000, summer), R81s(Nokian Haakapiilatta 2, winter)
'02 MCS DS/W (retired)
United States Male View Bilbo Baggins's Space Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 16th, 2006, 03:29 AM   #5 (permalink)
xtremepsionic
Vroom!
xtremepsionic's Avatar
Local Time: 07:03 AM
This also depends heavily on the tire you're using. Usually lower profile/wider tires will tend to follow the road camber a lot more than skinny/smaller tires.
My MINI with 15" holies and 175/65/15 conti tracks EXTREMELY straight. On a flat level road I can easily go for 300-500 meters with my hands off the wheel (at highway speeds, 70mph). So if you have 15" tires like mine, expect nothing less from a tracking/alignment service.
Canada Male View xtremepsionic's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Feb 16th, 2006, 08:48 AM   #6 (permalink)
Perm
Perm's Avatar
Thanks for the replies.
I have checked the tyre pressure...... all ok.
I will look for a good tyres specialist to check the tracking......... other than ATS anyone recommend another major chain that you would trust for wheel alignment ?
Root Ginger who did you use?
Perm
Old Feb 16th, 2006, 08:52 AM   #7 (permalink)
St00ge
8/10 on the Stoogometer
St00ge's Avatar
Send a message via MSN to St00ge
Quote: Originally Posted by Perm
Hi,
Perm
i too have to hold my steering wheel slightly to the right to go in a straight line. My tyre pressures are all ok as well. I've had my steering re-aligned, didn't do anything really...i just live with it
Black MCS Alta CAI, MTH, OBX + One-ball, Alta Diverter w/ Sprayer, Recalibrated BPV, Alta 17% Pulley, Denso IK22s, Goodyear Eagle F1 GSD3s 215/40/17, Whiteline 20mm Adjustable Rear Swaybar, Ferodo DS2500s, Motul RB600, TCE SS braided brake lines
Old Feb 16th, 2006, 09:32 AM   #8 (permalink)
Mini Soph
Fastest feet in the west
Mini Soph's Avatar
Local Time: 01:03 PM
Sounds like your tracking's out.....Try Nottingham Alignment Service 0115 959 9144 based in Colwick
Old Feb 16th, 2006, 09:47 AM   #9 (permalink)
Perm
Perm's Avatar
ATS say they can not do the new MINI
Thanks for the information.
I called ATS who said they can not do the tracking on the new MINI as BMW have not yet realised the information on the correct settings!! Suggested I went back to the main dealer.
Does anyone know if this is correct? Does anyone have the correct settings for a MCS with 17" S-Spokes Alloys?
Perm
Old Feb 16th, 2006, 09:54 AM   #10 (permalink)
Mini Soph
Mini Soph's Avatar
Load of poop! I've had Mini's for 4 years and always taken mine to my Tyre distributor when i'm home and if i'm away the nearest alignment dudes and they do it fineeeeeee
Get them laser aligned you'll be back to normal in no time.
Old Feb 16th, 2006, 10:01 AM   #11 (permalink)
Perm
Perm's Avatar
Mini Soph,
Seemed a bit odd to me......... I will speak to Nottingham Alignment Service.
Have you used this company before ?
They are quoting max of £47.00 ; £32.00 + VAT for the front plus £10.00 for the rears if they need doing.
Does that sound about right ?
Perm
Old Feb 16th, 2006, 10:21 AM   #12 (permalink)
Mini Soph
Mini Soph's Avatar
One of my pals has used them.
Hmmmm I only pay about £25 I think
Where do you buy/get your tyres fitted? Take it down to them they should do a laster alignment for you.
Old Feb 16th, 2006, 01:45 PM   #13 (permalink)
Indigomatt
Talking
Any one know of a good 'trusted & visited' place up nr Glasgow...?
Also 16" Dunlop SP 3000A DSST tyres...£121.00 each ...any cheaper around....?
Ta, M.
Scotland   Reply With Quote
Old Feb 16th, 2006, 01:52 PM   #14 (permalink)
Perm
Perm's Avatar
I have booked myself in at Nottingham Alignment Service to be seen at 4:00 PM today.
Will report back on if they are any good / if it fixes my problem.
A link in case anyone else is interested.
http://www.alignment-services.co.uk/
Perm
Old Feb 16th, 2006, 02:26 PM   #15 (permalink)
Root Ginger
Perm
My mate owns a tyre and exhaust shop in Bedford so I go there. He hasn't got any alignment equipment but they have an account with ATS which is at the back of his shop. Did a fine job of my car as I have camber adjusters too.
Oh BTW all the measurements are in the Haynes manual.
Old Feb 17th, 2006, 12:56 PM   #16 (permalink)
Perm
Perm's Avatar
Quick update
Have now had my tracking fixed……… The two front wheels were both out and the rears where slightly out. As a result the car now drives straight and true again.
The whole process was more expensive than I would have like at £47.00, however the company inspired confidence and clearly knew what they were doing.
Mini Soph thank you for the recommendation.
Perm
Old Feb 17th, 2006, 01:06 PM   #17 (permalink)
Mini Soph
Mini Soph's Avatar
No probs glad your sorted Think my Front Left wheel bearing's on the way out LOL! Only had a new rear put on last wk! Ahhh dear!
Old Feb 17th, 2006, 01:19 PM   #18 (permalink)
Richard Crofts
THE STICK
Richard Crofts's Avatar
Sounds like the natural camber of the road pulling you left a touch. Tracking out usually fells like the car is side to side wishy washy on the road serface when travelling at a constant speed. Its difficult to spot in the town, usually becomes appaernt in the middlelane of Mway or on dueltrack. The slight pull or vear to left is probably nothing more than the natural tilt of the road...unless you have bashed some curbs or big potholes. Get it checked if you want to be safe its not that expensive.
R
Old Feb 17th, 2006, 01:20 PM   #19 (permalink)
Richard Crofts
THE STICK
Soz only just saw you have it fixed....Good to hear.
Old Feb 17th, 2006, 02:20 PM   #20 (permalink)
Perm
Perm's Avatar
£150 + Quote from BMW. !!!!!!
Hello,
Just for the fun of it I called my local BMW dealer for a quote to check and fix the tracking......
Now to carry out exactly the same work ( 4 wheel adjustment) on exactly the same machine as Nottingham Alignment Service they wanted to charge £150 plus adjustments !!!!!!
I suddenly feel a lot happier on spending only £47.00.
Perm
Tracking? marcou Wheels, Tyres & Brakes 6 May 26th, 2005 01:46 PM
Tracking Davislove3rd MINI Cooper S 10 Feb 13th, 2005 09:50 AM
Better tracking Hotelcalif Delivery, Shipping & Order Tracking 5 Sep 21st, 2002 12:10 AM
UK Tracking eBrit Exterior 11 Jul 30th, 2002 02:30 PM
Tracking?? hammarlund General Discussion 7 May 19th, 2002 03:52 PM
