JCW Brakes, Braided Hoses, 5 dot 1 Brake Fluid ? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Mar 5th, 2006, 09:48 AM
Wandering....
Local Time: 07:12 AM
Male
I've been looking at various brake upgrades over the past few weeks.
I'm thinking I'll stick with JCW now, as I couldn't be bothered faffing around with spacers to make different wheels fit, plus I must admit, as I have gone down the JCW route with the engine upgrade, seats, etc, I think I'd prefer to keep the car 'pure' so to speak
However, everyone seems to agree that braided houses and better brake fluid make a massive difference? So I'm thinking I'll do this as well, and get a compromise solution.
Can anyone tell me the best place to get braided hoses, and what I should be paying - I know Lohen do them for about 60-80 quid?
Old Mar 5th, 2006, 04:00 PM
Local Time: 08:12 AM
United Kingdom View dipstic&dinnerlady's Hyper Blue & White 1st Gen MINI Cooper S Profile View dipstic&dinnerlady's Classified Ads
Jcw
Old Mar 5th, 2006, 04:28 PM
timmydamini's Avatar
Li'l ol' wine drinker, me
Ireland Male View timmydamini's Chili Red & White 1st Gen MINI Cooper S Profile
Hi Aiden,
Goodridge hoses are good, do a search for a local supplier.
These people in Mallow could post them to you, they do brake fluid as well:
http://www.ears.ie/ . Ask for David, tell him what your driving.
Don't go for full race brake fluid, try Mintex 'C' tech. I can check an empty bottle for the precise description if you wish.
I reckon, for you, JCW is the way to go. No issues with fitting, clearance, longevity etc. Though fixed calipers, (4/6 pots etc.), and lighter two piece discs perform better, they require a bit more effort in fitting and maintenance etc.
Tim
Old Mar 5th, 2006, 05:08 PM
obehave's Avatar
Mini Mod
Local Time: 03:12 AM
Stoptech also make lines, it's what I have.
There's also ATE Blue
Not saying they're better, just giving other options.
Old Mar 5th, 2006, 07:01 PM
Wandering....
Male
Thanks guys
Tim, I might give that fella a call next week then - in fact, I might try the hoses and fluid first, see how that goes......
Old Mar 5th, 2006, 07:48 PM
Ireland View brady's Dark Silver & Black 1st Gen MINI Cooper S Profile
i had that mintex fluid in mine with braided hoses and it was very good, i enquired about different fluid at the time and was told to stick to that mintex stuff
Old Mar 5th, 2006, 07:50 PM
Wandering....
Male
Didn't change pads or anything?
Old Mar 5th, 2006, 09:22 PM
obehave's Avatar
Mini Mod
Aiden;
I first did a hose and fluid change a couple years ago.
Made a nice difference. Clamping force doen't change but the initial bite feels better.
Old Mar 5th, 2006, 09:24 PM
Wandering....
Male
Quote: Originally Posted by obehave
Aiden;
Good start for me then - think I'll get that on the way
Old Mar 5th, 2006, 09:33 PM
obehave's Avatar
Mini Mod
It's a good safe start and easy to add to in the future.
I just had slotted rotors and new pads done last weekend.
I need to dump the BMW fluid I got at my 25K and put good stuff in there. Brakes are a bit spongy but stop very well now once they bite.
Old Mar 6th, 2006, 07:35 AM
Aiden,
If you're staying with standard calipers, I'd recommend changing the pads from the stock items.
Ferodo DS2500 are a good pad, no noise and can handle high temps; www.ferodo.co.uk
If you can't source locally try www.raceshopper.com
Green stuff is also supposed to be good, haven't tried them myself.
I'd still go for the works brake upgrade, if I was you. I think that the brakes on a MCS, (let alone a Works S), need to be a bit better than stock,
Old Mar 6th, 2006, 07:55 AM
REHW's Avatar
Just enjoy it!
Send a message via MSN to REHW
United Kingdom Male View REHW's Hyper Blue & Dark Blue 1st Gen MINI Cooper S Convertible Profile
Braided hoses and 5.1 fluid made the biggest difference on my car. They make a difference when things get hot as the rubber hoses expand making the pressure from the brake peddal ineffective and hence brake fade. For general road use I don't think they are needed unless you are really giving it prolongued abuse. On a track day its a different matter and within 3 laps you will suffer brake fade so makes this upgrade essential even with the standard callipers that I run.
As for upgraded pads you only need to change the fronts. I have run Red stuff and once hot they were fantastic but a little scarey on my commute into work on cold mornings as they don't work well when cold. I currently run green stuff and don't like these anything like as much. I am going to give some mintex pads a go next time. There are quite a few of the track day boys on here that will give you all the guidance you need on this subject. One of the advantages is the lack of dust which you will like when it comes to wheel cleaning duty!
Russell - I bought my hoses off Fabio which he had bought off Lohen but never had fitted.
Old Mar 9th, 2006, 01:52 PM
Wandering....
Male
I just ordered Works brakes
Set of braided hoses from Ears, € 100.00 plus postage, and a litre of Mintex C Spec for € 26.00
Fabio, are you paying attention !
Thanks for the pointers Tim !
Old Mar 9th, 2006, 03:52 PM
You know it makes sense,have had Works brakes on both my cooper s improves without going over the top.
  #15 (permalink)
Old Mar 9th, 2006, 03:55 PM
Wandering....
Male
Thats what I'm after, just a bit more bite and stopping power, without the need for spacers or added maintenance.......
stainless steel brake hoses lucachiarelli Wheels, Tyres & Brakes 14 Apr 14th, 2008 12:19 PM
URGENT: braided brake hose required for 52-plate MCS malross General Discussion 0 May 4th, 2007 09:35 PM
Braided brake lines - recommendations? malross Wheels, Tyres & Brakes 5 May 2nd, 2007 12:37 PM
JCW Braided Lines to Australia via Mail Order Boo First Generation MINI Tuning 6 Jul 21st, 2004 02:11 PM
