Problem with brake pedal - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Apr 26th, 2006, 08:11 AM
Local Time: 08:14 AM
United-Kingdom Problem with brake pedal
I have just had both front and rear brake pads replaced and as expected they the brakes are a bit spongy. This is only until the "bed" in properly. But since they have been changed I have noticed that when I press down on the brake pedal there is a noise similar to air escaping. Sounds like when you put your foot down on an foot pump without the nozel being attatched to anything.
Any ideas???
Old Apr 26th, 2006, 08:27 AM
Capsaisin's Avatar
cave capsicum
Local Time: 07:14 AM
United Kingdom Male View Capsaisin's Chili Red & Black 1st Gen MINI Cooper S Profile
Usually you can only hear this if the engine is switched off, it may be the slight, short hiss of air from the brake servo. You break () the vacuum in the servo when you push on the brake pedal.
If you can hear it over the noise of the engine and it continues for as long as you are pressing on the brake pedal, then maybe there's a hole in the servo diaphragm??? But if this were the case you would lose braking effort and the brake pedal would probably go rock hard.
Stick your head under the bonnet and get a mate to press the brake pedal, with the engine running.
If you just get a short, faint hiss, I guess this is normal.
Old Apr 26th, 2006, 08:30 AM
OllyH
Send a message via Skype™ to OllyH
United Kingdom Male View OllyH's Classified Ads
Hi - just a quick question, is the noise heard when you press down on the brake, or as you take your foot off it, releasing pressure? If it is the latter, this is what was happening on my car. MINI looked at it and diagnosed a loose servo valve (I think) and it was repaired undert warranty.
Old Apr 26th, 2006, 10:55 AM
It happens when pressing down on the pedal while the engine is on. It has only occured after getting my new pads fitted
Old Apr 27th, 2006, 08:21 AM
Capsaisin's Avatar
cave capsicum
Yeah, could be the servo valve. Something to do with the servo anyway.
Old Apr 27th, 2006, 08:54 AM
KrisMcGrath's Avatar
Send a message via MSN to KrisMcGrath
United Kingdom Male View KrisMcGrath's Dark Silver & Black 1st Gen MINI Cooper S Profile View KrisMcGrath's Classified Ads
as long as accelarate pedal works im happy
Old Apr 27th, 2006, 02:14 PM
Just tried my mates two week old mini cooper and its makes the same noise. Can hear it without the radio on. I guess its always been there but just only noticed it know becuase I've been paying attention to the brakes after changing them
Cheers guys
Brake pedal Yui First Generation Faults & Fixes 7 Dec 9th, 2010 01:12 PM
Brake pedal problem Journeyman First Generation Faults & Fixes 4 Sep 28th, 2007 11:47 AM
Help - Brake Pedal Whoosh new_mini First Generation Faults & Fixes 4 Sep 21st, 2006 06:39 AM
Brake pedal click dancefreak First Generation Faults & Fixes 0 Mar 23rd, 2005 07:57 AM
Loose brake pedal jzlemon First Generation MINI Cooper S 4 Mar 9th, 2004 09:16 AM
