Changing tyres affects gearing and speedo? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old May 25th, 2006, 08:52 PM
gezmedinger's Avatar
Local Time: 08:14 AM
United Kingdom Male View gezmedinger's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile
I just had a thought as I put some Goodyear Eagle F1 205/50/R16 tyres on the rear of my MCS to replace the Dunlop 195/55/R16s runflats that were on previously. You can quite clearly see that the effective size of the wheel is now much smaller on the back than the front (due to the difference between the 50s and the 55s). Should I put the same tyres on the front, wouldn't this be equivalent to shortening the gearing? Won't this mean I'll spin higher RPM at 80mph on the motorway, read a higher mph than true anyway as the wheels will be spinning faster, and also probably increase fuel consumption?
Any thoughts anyone?
Old May 25th, 2006, 09:05 PM
British SD's Avatar
Northern Monkey!
Local Time: 01:14 AM
Canada Male View British SD's Chili Red & White 1st Gen MINI Cooper Profile
For safety reasons and handling, should have the same sizing & tires on all 4 wheels. Its not a F1 car!
Old May 25th, 2006, 09:17 PM
frylock's Avatar
Local Time: 02:14 AM
United States Male
I agree with British SD--for safety's sake keep all 4 the same. Also, you're probably correct that larger tires would increase fuel consumption. On the other hand, all of these things might turn out to be barely noticable. If you like the look of large wheels on the back, keep it. Just drive carefully for the first few weeks.
You might also find that wider tires are more subject to hydroplaning--especially in a small car like the MINI.
Old May 25th, 2006, 09:41 PM
MINIAC's Avatar
Canned
Local Time: 12:14 AM
You should go with 205/50-16 on all four wheels ...
Gearing change will not be that significant:
Name:	195-55-16 vs 205-50-16.png
Old May 25th, 2006, 09:52 PM
obehave's Avatar
Mini Mod
Local Time: 03:14 AM
I run 205-50 16s in autocross and they make a nice difference.
I heartily agree with the others that mixing tires like you have mentioned is a bad idea..
Old May 25th, 2006, 10:25 PM
PmP's Avatar
PmP
GP 06 MCS 0380
Northern Ireland Male View PmP's Dark Silver & Black 1st Gen MINI Cooper S Profile View PmP's Classified Ads
I do alot of motorway driving to and fro to work and ive driven on my 17's and 18's and there is a sizeable difference in the circumference of the two sets. So it stands to sense the larger ones will take you further for everyone revolution of the driveshaft. And if the police put a hairdryer on me and I sat at 60mph past them, I would be going slightly faster on the 18's.
I swear that at 70mph on motorway on 18s the rev counter needle sits slightly lower than with the 17's on. Weight difference of certain rims may also contribute to differences in speeds and mpg
Old Jun 4th, 2006, 10:38 PM
eltel's Avatar
MINIstry of Fun
Local Time: 05:14 PM
Australia Male View eltel's Liquid Yellow & White 1st Gen MINI Cooper S Profile
This website may help you determine the effects of wheel and tyre changes.
http://www.miata.net/garage/tirecalc.html
Old Jun 5th, 2006, 07:51 AM
Electric Blue's Avatar
Local Time: 07:14 AM
or this one:
http://www.powerdog.com/tiresize.cgi
Specification Sidewall Radius Diameter Circumference Revolutions Speedometer Odometer Difference
195/55-16 4.2" 12.2" 24.4" 76.8" 825/mi 60MPH 10000mi N/A
205/50-16 4.0" 12.0" 24.1" 75.6" 838/mi 61MPH 10155mi -1.5%
Oh, and as long as you have the same size tyre on each axle you are ok as far as the law goes. I have ran wider rims on the back of RWD cars for years (so do manufacturers). I can't see any safety problem with running undriven wheels with different tyre sizes to driven wheels.
In answer to your question, theoretically the difference is 1.5% as shown above, BUT, your speedo will be a touch out anyways (mine is about 2 mph out at 70mph), the only time to worry is when you are changing to a LOT bigger rolling radius. The 205s will actually reduce rolling radius so technically you should accelerate a touch faster (probably not noticeable, they would also have to be on the front)
Old Jun 5th, 2006, 06:16 PM
Suzrider's Avatar
United Kingdom Male View Suzrider's Electric Blue & White 1st Gen MINI Cooper S Profile
Hang on there! Different sizes on front and rear is bound to affect the ABS system and the tyre pressure warning system because they both work on the rotational speed of the wheels. A difference in the effective circumference of the wheels is bound to affect the systems.
Probably affect other systems as well especially the braking force distribution systems and possible the traction control. Anybody?
Not sure I'd feel safe thinking the ABS was there and working when it might not be, in a crisis.
Changing the speedo and REV zero_cool First Generation Interior & Ice 2 Feb 15th, 2007 08:24 AM
When changing Central Speedo from Mph to Kph... Fabio First Generation Interior & Ice 18 Sep 23rd, 2006 06:07 AM
Changing Cental Speedo Dial Fabio First Generation Interior & Ice 10 Sep 5th, 2006 11:09 AM
Changing Speedo - How far has your mini travelled vonny First Generation Interior & Ice 22 Mar 21st, 2005 06:41 PM
Changing Sparco seats affects airbag sensor? murphymok First Generation Interior & Ice 18 Dec 5th, 2003 06:09 PM
