JCW 18" Wheels on a Mini Cooper - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jun 16th, 2006, 03:42 PM
Richard Morris's Avatar
Local Time: 07:14 AM
Hi guys, couple of quick questions you might be able to help me with.
Would like to get some 18" JCW wheels on my Cooper, and was wondering if I will run into any problems, i.e. rubbing on the arches, drastic changes in handling.
At the moment I have 16" Bullets with Dunlop run flat tyres on. I would obviously be getting some much nicer tyres put on the JCW's (and deffo NOT run flats).
Has anyone got any thoughts on this?
Also, reckon it'd look good? Have loved those wheels since I saw em.
Old Jun 16th, 2006, 04:53 PM
minicore's Avatar
Super Moderator
Local Time: 08:14 AM
United Kingdom Male View minicore's Chili Red & Body Color 2nd Gen MINI John Cooper Works Profile
They be fine, but you'd probably need to fit wheel lock limiters to prevent damage to the arches. Performance and ride would likely suffer, but you can't put a price on style, can you?
Old Jun 16th, 2006, 05:13 PM
nylo's Avatar
Totally Mental!
Northern Ireland Female View nylo's Space Blue & Silver 1st Gen MINI Cooper S Profile View nylo's Classified Ads
No, you won't run into any problems if you leave the suspension standard. Even dropping it 30mm on Eibachs shouldn't do too much harm, though there may be a bit of rubbing- do a search for info as this has been covered loads.
What minicore says is true, theoretically the dealer should fit the limiters when fitting the wheels, but it is possible to do without them (I didn't have them fitted, and have had no problems whatsoever).
I'm sure you will notice a difference in handling. Although you have runflats already, there is obviously a lot less tyre there when you jump to 18s (though the JCWs come with 205/40 18 as opposed to the more usual 205/35 18 most people go for when buying 'normal' tyres), so you will feel bumps a bit more. Having said that, as long as you're careful (avoiding potholes etc), you shouldn't have too many problems.
If you like them, go for it. I did, and love them to bits- how they look (just about!) outweighs the ride
Old Jun 16th, 2006, 06:12 PM
I checked out the change in rolling radius, is only a change of about 0.4" so should not be too much of a problem there.
Could someone explain what these "limiters" are that the dealer should have fitted?
Also, I will probably get the wheels sprayed white (done properly though). Should be quite a rare combo! Lol.
Old Jun 16th, 2006, 06:20 PM
nylo's Avatar
Totally Mental!
I have a notion it's something to do with the offset. The JCW wheels have an offset of 52, which is a bit of an oddity. The limiters are designed to 'limit' full lock to prevent the wheels fouling the arches.
I don't corner particularly hard or aggressively, so have never had a problem, though if that is your driving style, maybe the wheels would come into contact with the car on full lock...
Old Jun 17th, 2006, 08:07 AM
venox22's Avatar
only the brave!
Send a message via AIM to venox22 Send a message via MSN to venox22
United Kingdom Male View venox22's Indi Blue & White 1st Gen MINI Cooper S Profile
like nylo said, i didnt have the limiters fitted and no probs what so ever with mine
Mini Cooper S or JCW for "P-PLATES"??? bugiz Australia 17 Oct 3rd, 2006 09:29 AM
Mini Cooper 17" wheels MaRKaSaURuS Wheels, Tyres & Brakes 3 Oct 8th, 2004 07:53 AM
PW / B, Works, Aerokit, 18" JCW Wheels & JCW Seats - Pics , especially for Sham ! AidenL First Generation Works 26 Apr 15th, 2004 08:58 PM
Attn Canadians - JCW 18" wheels now available at MINI dealerships in Canada!! milliethemini Canada 0 Mar 1st, 2004 08:43 PM
