Performance Torque
Old Jul 6th, 2006, 03:25 PM   #1
MiniLover247
///Michael
MiniLover247's Avatar
Local Time: 06:20 AM
Send a message via AIM to MiniLover247
18" tires
so i want to run 18" wheels on my mini. most people have 215/35/18 tires, but some have 225/35/18. if i got 225/35/18, that would make the tire heigth 10mm taller, so am i correct in thinking it would be a little bit of a smoother ride? or does it even make a noticeable differance. what would be some pros and cons on these choices?
thanks in advace
michael
Happily Motored
United States Male View MiniLover247's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 6th, 2006, 05:03 PM   #2 (permalink)
monkeynuts
my ponies have escaped!!!
monkeynuts's Avatar
Local Time: 01:20 PM
think its more related to clearance than comfort, but i could be wrong
im sure a tyre anorak will be in shortly
m o n k e y : n u t s
Old Jul 6th, 2006, 05:24 PM   #3 (permalink)
PW/B_JCW210
PW/B_JCW210's Avatar
the tyre height would not be 10mm higher, it would be 10mm wider.
The height of the 215/35 would be 75mm and the 225/35 would be 79mm, so there would be a negligible difference in the ride quality, that difference is about the same as comparing a new tyre with one that is part worn....
I have 215/35/18's on my MINI and the ride is pretty good, mind you these are non run flats, that makes the biggest improvement in the ride quality.
Replacement tires for 15" "standard" wheel in U.S. mokap Wheels, Tyres & Brakes 2 Sep 8th, 2006 07:28 PM
For Sale - Pirelli P Zero Corsa "track" tires AS NEW 17" x 4 worldweb For Sale 4 Jul 10th, 2005 11:07 PM
Want to change from RF tires to "ordinary" tires... Pete Peterman Wheels, Tyres & Brakes 1 Apr 12th, 2004 04:03 PM
New wheels/tires: 15" polished Rota Circuit 8s, Yokohama AVS ES-100 tires ZAMIRZ Wheels, Tyres & Brakes 15 Mar 11th, 2004 03:26 PM
17" wheel with normal tires vs. 16" wheel with runflat tires Wayne Engine & Drivetrain Tuning 13 May 19th, 2002 07:39 PM
