Old Jul 16th, 2006, 08:44 PM   #1
mrmikimaus
HisHaiNess - MINIster
Local Time: 10:13 PM
run flats on regular rims. my observation.
considering that run flats cost substantially more, i was initially hesitant about swapping out my rims and re-using the stock runflats, i still am after. my thoughts and observations.
1) stock rims weigh in at more than 10kg each, forged, 6.9kg.
2) original rims have a different rolled profile to prevent bead slippage.
3) tire pressure monitoring system is in e hub, not the rim.
4) runflats not designed to work on regular rims. once deflated, it's substantially easier for bead to slip off during hard cornering.
5) the weight of the runflats is not that much heavier. it's is, but not substantial.
i'm posting cuz had i known (4), i would have re-considered.
The more you know, the less you know you know...
Singapore Male View mrmikimaus's Chili Red & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old Jul 16th, 2006, 08:53 PM   #2 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 07:13 AM
Online
Why would you be driving aggressively on a deflated tire
Old Jul 16th, 2006, 09:37 PM   #3 (permalink)
Root Ginger
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
Local Time: 03:13 PM
It can be very easy to do as the runflat indicator is quite frankly poor. It is possible to drive for significant time before it realises the tyre is deflated. Seems to work well on straight continuous speed roads but for round town you can drive a long way without it warning you, even when there is 0psi in the tyres.
It was acceptable in the 80's
Old Jul 16th, 2006, 09:37 PM   #4 (permalink)
Paul
Trained Monkey
Paul's Avatar
Online
There is no tyre pressure monitoring system so to speak, it's an adaptation/advancement of the ABS sensor, it detects the speed the wheels are turning, and bases the "flat" warning if one is spinning faster than the others.
Old Jul 16th, 2006, 09:37 PM   #5 (permalink)
Paul
Trained Monkey
Paul's Avatar
Online
And on the above, I detected a flat on an S before the sensor did!
Old Jul 16th, 2006, 10:40 PM   #6 (permalink)
minigolf
Blue is the colour!
minigolf's Avatar
Local Time: 01:13 AM
I'm surprised you found someone willing/able to fit a runflat tyre on a rim not designed for such tyres.
Australia Male View minigolf's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Nov 15th, 2006, 08:54 PM   #7 (permalink)
nylo
I will NOT be cured!
nylo's Avatar
So is fitting RFs to non runflat wheels a big no-no then?
Northern Ireland Female View nylo's Space Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Nov 15th, 2006, 09:33 PM   #8 (permalink)
humph
Back To My Old Self
humph's Avatar
That appears to depend on the brand of runflat. The dunlop website for runflats clearly states that their tyres can be mounted on any rim. See the DSST section of the link below.
Dunlop Tyres UK
I asked the same question of pirelli with a view to using the runflats off my new Cooper on aftermarket alloys. Pirelli sent me the following reply via email.
"Thank you for your enquiry.
These tyres are recommended to be fitted to EH2 (Double extended Hump)
rims but, are permissible to be fitted to H2(Double Hump) rims."
This may help clear up a few things. I have to admit Pirelli's response didn't fill me with confidence.
MODERN MINI - BEST COOPER NOMINEE - PLEASE VOTE FOR ME!!!
Wales Male View humph's Pepper White & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Nov 15th, 2006, 09:44 PM   #9 (permalink)
nylo
nylo's Avatar
Interesting. As you say, the Dunlop site states "DSST-tyres can be mounted on any standard rim", so that would be a thumbs up form them.
What exactly does that email from Pirelli mean?
Have seen some rims on Ebay and was wondering about keeping RF tyres...
Old Nov 17th, 2006, 10:36 AM   #10 (permalink)
AlexF2003
AFRacing
AlexF2003's Avatar
Send a message via MSN to AlexF2003
It means you can fit run-flat tyres to any rim
Alex
Alex F - AFRacing LTD
United Kingdom Male View AlexF2003's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Mixing Run Flats with non Run Flats Aberdeen Al Wheels, Tyres & Brakes 3 Feb 2nd, 2007 03:38 PM
Subbing regular winter tires for performance fun flats samantha mini Wheels, Tyres & Brakes 4 Oct 28th, 2005 10:47 AM
run flats or regular tires? SD_David Wheels, Tyres & Brakes 12 Nov 16th, 2004 12:51 PM
Regular tires on run flat rims sammee Wheels, Tyres & Brakes 2 Apr 3rd, 2004 09:08 PM
