Do 18” wear badly? & advice on new!!! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jul 20th, 2006, 08:52 AM
Local Time: 07:10 PM
Just a little advice needed; am running 18” Yokos with lowered suspension and although there is plenty of tread left in the middle of the tyres they are really really badly worn round the edge.
Just wondered if this was typical of 18” and if there is any reason for it – is it worth getting the tracking on the car checked or anything like that? Or am I just doomed to having tyres that wear out quickly with my setup!!!
Looks like I’ll need some new ones…..did a search on here and seen www.mytryes.co.uk look like a good option – any others to recommend?
Don’t have runflats at the moment but might be tempted although don’t want to spend too much at moment so probably go with a standard cheaper premium tyre; but advice would be much appreciated.
Thanks again
Old Jul 20th, 2006, 09:21 AM
nylo's Avatar
Totally Mental!
Northern Ireland Female View nylo's Space Blue & Silver 1st Gen MINI Cooper S Profile View nylo's Classified Ads
I don't think it's typical of 18s (I have the Works wheels, and have had fairly even wear so far). I'm by no means an expert on this, but the veyr fact that you say it's lowered will almost definitely have something to do with it, your tracking may be out.
I think it probably depends by how much it is lowered too- that will affect the amount of wear and where it is...
Old Jul 20th, 2006, 10:08 AM
Hi,
Thanks for the reply.
The car has the mini schnitzer lowering kit on it; so i believe that is 30mm. I love it with the big 18" alpinas i've got on but god they've worn badly!
Still, it's well worth it but hey!
Old Jul 20th, 2006, 10:11 AM
nylo's Avatar
Totally Mental!
Is that just the springs? I know lavs had Schnitzer springs on his previous Cooper, albeit with 17s and runflats, but I don't think I heard him complaining of uneven wear. You might want to PM him and see if you can get some info....
Old Jul 20th, 2006, 10:16 AM
G-Man's Avatar
Cool CoopS
Local Time: 08:10 PM
England Male View G-Man's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
Are you running the right PSI?
Cause if the tyres are under inflated they will wear out on the edges and over inflated they will wear in the middle.
Old Jul 20th, 2006, 10:42 AM
Not sure what they are now – haven’t checked them in a while so could be down to that!
Do you know what PSI I should be running with 18”?
Sticker on inside of my door doesn’t have pressures for 18” wheels…I believe the newer cars might have this info though?
Old Jul 20th, 2006, 10:59 AM
Benmk's Avatar
United Kingdom Male View Benmk's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile View Benmk's Classified Ads
The car i had previously was lowered and it creates a negative camber (where the top of the wheels lean into the car) from the drop. Even if it is only 30mm and is still within the tracking tolerances it will still cause the tyre wear to be uneven. You are most likely to notice that the inside of the treads will wear more than the rest.
I have also noticed on a few MINI's that the outside edge likes to wear a little more.
With these factors combined it will account for more wear to the edges than the middle of the tyre.
Also bear in mind that the rear wheels dont turn so that with a negative camber they will just lean on the inside of the tread slightly harder cpmpared to the front that will be turning on the inside of the tread.
Hope that helps
Ben
Old Jul 20th, 2006, 11:10 AM
Step_7's Avatar
Whining....
Northern Ireland Male View Step_7's Dark Silver & White 1st Gen MINI Cooper S Profile View Step_7's Classified Ads
You can try www.blackcircles.co.uk for prices as well.
Old Jul 20th, 2006, 05:06 PM
Cheers for all the info, much appreciated.
As above - anyone know what PSI mini recommend for 18" tyres?
Thanks a lot
Old Jul 20th, 2006, 05:29 PM
Richard Crofts's Avatar
THE STICK
I am running 34 PSI on 18" Dare X4s with Toyo rubber. Seems to wear OK at the moment 6k miles so far.
My missus had Eagle F1s on her Corsa with 17's and they recommended 36-38!!!
Old Aug 12th, 2007, 01:21 PM
MINI EXPERT
United Kingdom View Daryl575's Classified Ads
hi, im running 18" wheels on my mini and they seem to be wearing fine. i have got around 32psi in the tyres and they tend not to wear to much. on the cooper s works wheels they recomended from 32-36 depending on the style of driving
Old Aug 12th, 2007, 02:39 PM
Drewski's Avatar
United Kingdom Male View Drewski's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
Mines is lowered 25-30mm on eibachs and i have 215/35/18 tyres and no uneven tyre wear. I run 33 front 31 rear
Old Aug 15th, 2007, 12:40 PM
aceman's Avatar
That Sound Dude
Send a message via MSN to aceman
Local Time: 06:10 AM
Australia Male
18's here as well. Lowered on Alta's 30mm. Run 38psi, rough as buggery, but it protects the rims from all the rough roads out here.
Tyre wear seems ok after about 10,000kms
Old Aug 17th, 2007, 11:17 PM
Damo's Avatar
Lights are on but...
Send a message via MSN to Damo
United Kingdom Male View Damo's Solid Black & White 1st Gen MINI Cooper S Profile View Damo's Classified Ads
I have Yoko 215/35 R18, with Eibach lowering springs. Fronts have just been changed after 20k and have even tyre wear (I run 34 front 32 rear).
Rears still have loads of life left but have worn more on the inside edge due to the camber at the rear.
Before I had the Yokos I had falken Fk451's. Fronts did 18k, where the rears did 36k (had to sets of fronts and 1 set of rears, again inside edge was the reason to change as got illegal. Change my wheels and tyres thought that time.
  #15 (permalink)
Old Aug 18th, 2007, 12:00 AM
adam_Randell's Avatar
Send a message via MSN to adam_Randell
United Kingdom Male View adam_Randell's Pepper White & Black 2nd Gen MINI Cooper Profile View adam_Randell's Classified Ads
i have 18s on my R56 MC and they are fine - wearing alot better than the original 15s. Done about 5k on them and cant really notice that much wear in them. however - handling is different especially in the wet!
Leather Wear & Tear ST967 Australia 2 Mar 26th, 2007 09:50 AM
Urgent advice needed - tapping noise + poss tensioner wear mikeythemini First Generation Faults & Fixes 7 Apr 24th, 2006 08:12 AM
lowered & stiff - tyre wear GTT 280 Wheels, Tyres & Brakes 1 Apr 9th, 2005 06:36 PM
Dunlop 17" wear indicators & replacement?? bkwalker Wheels, Tyres & Brakes 13 Nov 13th, 2003 09:51 PM
