What size tyres on JCW 18's - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Aug 10th, 2006, 11:51 AM
venox22's Avatar
only the brave!
Send a message via AIM to venox22 Send a message via MSN to venox22
Local Time: 03:58 AM
United Kingdom Male View venox22's Indi Blue & White 1st Gen MINI Cooper S Profile
Ready to replace the dreaded runflats with Goodyear F1's but they dont come in 205/40/18 so what size should i go for??
225/35/18
215/35/18
was the JCW rim designed for 205 wide tyres or was just a last min runflat they stuck on it, what effect does running wider tyre have, does make the tyre deform??
Anyone got any pics of 18'' wheels on 35 tyres with normal S SS+???
Old Aug 10th, 2006, 12:21 PM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
Well the 40 on 205/40/18 is the height as a percentage of the width in mm.
A 205/40 has a height of 82mm (205 / 100 x 40)
A 215/35 has a height of 75.25mm (215 / 100 x 35)
A 225/35 has a height of 78.75mm (225 / 100 x 35)
I know the JCW wheels require a rack reducer to be fitted to stop them rubbing on full lock. I don't know how much room this gives you before they rub, might need to take a look with the wheels on full lock to decide which width to go for but even with the 225 your only adding 10mm each side and I would of thought the rack reducer would give you a little more room than just 10mm. The 225 wheel is also the closest to the original tyres height too.
It was acceptable in the 80's
Old Aug 10th, 2006, 08:08 PM
Damo's Avatar
Lights are on but...
Send a message via MSN to Damo
United Kingdom Male View Damo's Solid Black & White 1st Gen MINI Cooper S Profile View Damo's Classified Ads
225/35 R18 won't fit The minimum wheel width for these tyres is 7.5" and the JCW wheels are 18" x 7"
Only option in my opinion is 215/35 R18 as this is the most popular size. I wouldn't go for the 205/40 R18 as only know of 2 options, the OEM and a Micehlin, plus they're not cheap.
Plus 215/35 R18 don't rub even without the steering lock limiter
Old Aug 10th, 2006, 08:21 PM
venox22's Avatar
only the brave!
cool, 215/35/R18's it is then
does 35 profile look too skinny with normal SS+?????
Old Aug 10th, 2006, 08:29 PM
Damo's Avatar
Nah, makes the wheel look bigger
Heres a photo of my old cooper with 215/35 tyres but it was lowered....
...can't find any pics with those tyres before it was lowered
Old Aug 10th, 2006, 09:07 PM
venox22's Avatar
only the brave!
yeah that does look good, just dont want to end up lowing it after the tyres!!
anyone got any pics of 215/35/R18's on normal Sports Suspension Plus????
Also, just found Michelin in 205/40/R18 Pilot PS2's, Tyre test gave almost same marks Goodyear F1's, anyone used these???
Old Aug 10th, 2006, 09:15 PM
Damo's Avatar
Dunno but, at the moment, mytyres has them at about £10 more the the 215/35 Eage F1's which isn't to bad.
Old Aug 11th, 2006, 09:55 AM
MiniBimmer's Avatar
Portugal
Hello
When I go to put 18" wheels goes to be in the measure 205/40 and tires PS2 that are very good.
Best Regards
Old Aug 14th, 2006, 07:48 PM
venox22's Avatar
only the brave!
so just been digging around mainly mister tyres himself's (Damo) posts, so should i go
215/35/18 Eagle F1's
215/35/18 Yoko Parada's
or 205/40/18 Michelin PS2's
according to tyretest, the Eagle is better all round, but the yoko is more easily availible and has a wider look to them, and the Michelin will fill my arches better(normal S sports suspension plus) and has almost same results on tyretest as the Eagle F1 but more expensive!!
HELP!!!
Old Aug 14th, 2006, 08:28 PM
Damo's Avatar
Eagles...personally think Yoko's would be better in the dry, but the Eagle defo in a league of their own in the wet.
Old Aug 14th, 2006, 08:31 PM
venox22's Avatar
only the brave!
right......think the only thing stopping me getting the eagles is, will the gap between the arches look too BIG????
Old Aug 14th, 2006, 08:42 PM
Damo's Avatar
Look at standard 15" wheels and tyres as the overal diameter of the 215/35 R18 is the same as the standard OEM 15's.
Old Aug 14th, 2006, 09:03 PM
venox22's Avatar
only the brave!
now im thinking Yoko Parada's after reading this
http://www.mini2.com/forum/engine-dr...upgrade-9.html
argh!!
Old Aug 14th, 2006, 09:06 PM
venox22's Avatar
only the brave!
now thibking the michelin PS2's after reading this
http://www.tirerack.com/tires/survey...ay.jsp?type=MP
double argh!!!
  #15 (permalink)
Old Aug 15th, 2006, 08:24 PM
venox22's Avatar
only the brave!
got a qoute of £102 per tyre all in for the yoko's best ive got is £128 all in for the F1's
How do the yoko's/F1's wear compared to the run shats???
Wheel Rumble on Size 18's Tone General Discussion 2 Jun 7th, 2007 06:17 PM
new JCW Alloys but what size tyres?? jjmyers Wheels, Tyres & Brakes 2 May 3rd, 2007 08:50 PM
JCW 18's DamoSXI Wheels, Tyres & Brakes 13 Jun 20th, 2006 10:48 PM
wanted: jcw 18's or oz 18's photo's Thadée Wheels, Tyres & Brakes 5 Jan 24th, 2006 02:59 AM
JCW 18's or Kahn RS-C? cfranklin Wheels, Tyres & Brakes 8 Oct 28th, 2004 03:21 PM
