| Tags: pressure, runflat, tyres |
| MINI2 Newbie Join Date: Aug 2006 Local Time: 04:05 AM
Offline | runflat tyre pressure!! help hi guys! can somebody help!! my mini coppers s has runflat tyres and the tyre pressure light has come on !!! does anyone know the correct pressure for the front and rear is ??? thanks for your help guys !!!! ![]() |
| MINI2 Regular Join Date: May 2006 Location: Central California Local Time: 08:05 PM
Offline | If you open your drivers side door, there should be a decal listing tire pressures. I believe mine says 35 psi if you plan to drive under 100 mph, and 39psi for over 100mph. |
| Take me down to Paradise Join Date: Mar 2004 Location: David McGhan's World Local Time: 01:05 PM
Offline | Have you checked for punctures? As above though, 35-40 will probably be fine. Might be an idea to monitor the pressures over the next few days.. you may have a slow leak or something ... - Global Moderator - MY BLOG - Global Procrastinator - ![]() ... You're considering hiring me for your latex salesman ... |
| Stu | Bear in mind that it isn't actually a tyre pressure monitoring system as such. It works off measuring the rotation of the wheels via the ABS sensors. A flat tyre will have a smaller rolling radius, so will therefore have to turn faster than the other wheels. This means that to trigger the system you have to have lost quite a lot of air from the tyre. So it's definately worth checking your pressures. When they are ok, reset the system following the instructions in the manual. |
| Runflat tyre always losing pressure | Scousemouse | Wheels, Tyres & Brakes | 17 | Feb 27th, 2007 07:57 PM |
| Tyre Pressure | WhiteStripes | Wheels, Tyres & Brakes | 4 | Jan 4th, 2007 05:17 PM |
| 17" Non-runflat Pressure? | S33BBY | Wheels, Tyres & Brakes | 12 | Apr 2nd, 2006 04:53 AM |
| Proper tire pressure for Runflat Dunlop 5000s | foxmoor | Wheels, Tyres & Brakes | 3 | Mar 12th, 2006 04:05 PM |
| Tyre Pressure | MiniAdventurer | Wheels, Tyres & Brakes | 9 | Dec 5th, 2003 04:49 PM |
