probably a stupid question - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jan 2nd, 2007, 02:20 PM
Local Time: 10:36 AM
England
if i change my normal wheels for some aftermarket ones will it efect my runflat sensors
Old Jan 2nd, 2007, 02:36 PM
frylock's Avatar
Local Time: 04:36 AM
United States Male
Probably. When I changed my wheels, I had to reset the runflat sensor. It's easy to do--just hold the button by the emergency brake while you're starting the car.
Old Jan 2nd, 2007, 02:45 PM
sef's Avatar
sef
Local Time: 09:36 AM
United Kingdom Male View sef's Hyper Blue & Black 1st Gen MINI Cooper S Profile View sef's Classified Ads
If they are non runflat I think that the light will stay on... You may need to go to a dealer to have it switched off...
Old Jan 2nd, 2007, 02:50 PM
England
no they r runflat thanks for your help
Old Jan 2nd, 2007, 03:42 PM
murmini's Avatar
Send a message via AIM to murmini
Local Time: 05:36 AM
United States Male
The runflat sensor is really misnamed, it simply looks at rotation of the 4 wheels and reports if one of them is making more rotations than the others, indicating a deflated or partially deflated tire due to it having a slightly different circumferance and subsequently making more/less revolutions than the others. It does not have any special relationship with runflats. So, reset the sensor and motor on.
Old Jan 2nd, 2007, 04:10 PM
humph's Avatar
IJ 2009 - Team 81
England Male View humph's Dark Silver & Silver 2nd Gen MINI Cooper S Clubman Profile
As murmini says the runflat indicator is actually the abs sensor and is looking for one wheel rotating at a different speed to the others. There are no pressure sensors built into the rims or any such nonsense. And that popular myth that tyre fitters like to spread about the indicator being permanently on if you change rims or move to none runflat tyres is nonsense.
Old Jan 5th, 2007, 11:27 PM
marcy's Avatar
howay the lads
England Male
tis true run-flat indicator works fine with any size wheel or run-flat or non run flat tyre just reset it with the switch under you hand brake keep it pressed the light will go off will still come on and work as normal if you get a flat
Old Jan 5th, 2007, 11:44 PM
ONED's Avatar
SUCKIN DIESEL!!!!
United Nations Male View ONED's Nightfire Red & Black 2nd Gen MINI Cooper Diesel Profile
That seems to be that sorted then!
A Really Stupid Question Birdog First Generation MINI Cooper S 16 Jul 13th, 2006 08:56 AM
Stupid Question I know... MarkW19 First Generation MINI Tuning 11 Apr 28th, 2006 06:55 AM
Could be seen to be a stupid question but.... tatty First Generation MINI Exterior 6 Jul 3rd, 2005 04:35 PM
