Brake upgrade help needed..... - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Jan 25th, 2007, 04:19 PM
Local Time: 03:01 AM
I am just in the process of upgrading to jcw brake kit on my wife's mcs jcw. I have got my local dealer to supply them for £450 plus vat. However, after seeing the new r56 jcw drilled and slotted front discs, i now want these.....
I spoke to the local dealer again, who was very helpful and after digging around confirmed that dimension wise these discs are the same size as the jcw brakes for the r53 i.e 294mm by 22mm. The price is only about £10 more per disc.
However, he said there is a note on the system saying that these disc should only be used on the r56 model.
He couldn't say why.....
Does anyone have an answer, because I can't see why not, they are the same size and I assume the stud spacing/bolt holes are the same.
Any ideas....??
Old Jan 25th, 2007, 05:26 PM
SteveM3's Avatar
Local Time: 04:01 AM
Any ideas....??
Chris at Woodmans as already said that you can't fit r56 brakes on an r53 so he may know why.
http://www.mini2.com/forum/group-buy...53#post2863061
Old Jan 26th, 2007, 07:05 PM
Local Time: 10:01 PM
United States Male
United-States
It may possibly be because the bolt size has changed from 12 to 14mm. If you have a late build '06 or GP they utilize the 14mm bolts. My guess is that they wii fit the later build '06's. If someone could verify this and you still wanted to do it TSW is having some studs made to go from 14mm to 12mm for people that want to use wheels with the 12 mm bolt holes
Steve
Brake upgrade Garylimey First Generation Works 5 Jan 16th, 2007 04:27 PM
Simple Brake Upgrade cooperstan First Generation MINI Tuning 12 May 14th, 2005 12:07 PM
Alternator Upgrade needed? BluMiniMe First Generation Interior & Ice 2 Aug 30th, 2004 01:33 PM
Brake upgrade - new opinions !! Boris First Generation MINI Tuning 11 Dec 16th, 2002 09:29 PM
