FOMSPORT
Tags: , ,
Old Apr 1st, 2007, 07:57 AM   #1
poddy
Local Time: 10:40 AM
Brake Performance after track day
Hi,
Had a great day last Saturday at Oulton Park, had 1/2 day track-day in my standard Mini Cooper.
I'd recommend this to anyone so you can fully explore the handling, I struggled to make the Mini slide even at high speeds in a sharp hair-pin-felt like my organs were being moved around!
Anyway, you can guess the brakes took some stick, although at least every five laps (out of a total of about 30) I brought the car in for 10 mins to cool down etc.
Since then we think the brakes are performing slightly less well, not dangerous but just not as good.
Trying to determine if this is the fluid/pads/discs, pads and dics look fine, could this be the fluid having boiled?
The pedal just feels slightly lower and braking not quite as immdiate but I wouldn't say the pedal was spongy.
Hope you can help.
Eifion
Old Apr 1st, 2007, 09:30 AM   #2 (permalink)
robbo mcs
Track Addict
robbo mcs's Avatar
Local Time: 07:40 PM
Quote: Originally Posted by poddy (original)
Hi,
Hope you can help.
Eifion
Hi,
The most likely thing is that the brakes need bleeding, which is a minor procedure.
Robbo
Mods: Hartge kit, CAI, oil cooler, headers, cat & exhaust, bilstein coilovers, adjustable bars & camber plates, quaife diff, roll cage, seats, harnesses
GO MADDIE and SPARKY!
Australia View robbo mcs's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 1st, 2007, 09:37 AM   #3 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
Talking Oulton Park
...what an excellent circuit!!!!!!!!!!!!!!!
By the way, much better to do 10 minutes worth of slow laps than to bring your car in statically for 10 mins. Remember, air flow is key!! and the coolant system shuts off as soon as the engine stops running.
Cheers,
K.
Old Apr 1st, 2007, 03:51 PM   #4 (permalink)
HObzy
HObzy's Avatar
Careful - it gets addictive
Robbos more than likely hit the nail on the head.
United Kingdom View HObzy's Indi Blue & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 1st, 2007, 04:38 PM   #5 (permalink)
JAMIE1131
JAMIE1131's Avatar
yeah sounds like it needs to be bled, if the fluid has boiled it will be slightly darker than normal. bleeding the brakes is easy work.
United Kingdom Male View JAMIE1131's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 1st, 2007, 09:02 PM   #6 (permalink)
HObzy
HObzy's Avatar
You may not need to completely bleed them too - just til clear fluid comes through.
Old Apr 2nd, 2007, 07:35 AM   #7 (permalink)
poddy
Thanks everyone, will get one of those easy-bleed kits and give it a bash.
Cheers.
Eifion
Old Apr 2nd, 2007, 10:32 AM   #8 (permalink)
PmP
GP 0380
PmP's Avatar
If you take the pads out you may find they have cracked. Mine had a crack right across the face of the front pads.
Northern Ireland Male View PmP's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 2nd, 2007, 10:52 AM   #9 (permalink)
Richard Crofts
THE STICK
Richard Crofts's Avatar
Fluid probably got too hot if it was stock stuff. The pads may be well worn causing a need for more travel on the pedal if they were stock.
I'd suggest going to a better pad and higher spec fluid for the next time....you'll get more out of the experience. Or even better if you have cash to burn opt for JCWs or a BBK!
Obly problem with BBKs is you need to take some glue with you so you can stick your face back on when it gets sucked onto the screen under hairpin braking
Old Apr 2nd, 2007, 11:00 AM   #10 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Although it is extremely common for the brakes to feel pretty bad after a track day for a good 50 miles or so but if you are planning on doing future track days id recommend upgrading your brakes or atleast replacing your brack fluid more often maybe with higher temp fluid.
Thunderhill Track day 7-6-2006, lots of track time, low cost! ThePerfectLine Northern California Region 0 Jun 26th, 2006 09:59 PM
Track Day @ Autobahn Country Club South Track 7/7/05 Joliet, IL LugnutM3 MINI in Motorsport 0 Jun 9th, 2005 10:49 PM
track day brake pads gbuff1 MINI in Motorsport 16 Nov 20th, 2004 01:03 AM
