whats the best tyre psi - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Apr 10th, 2007, 03:05 PM
Local Time: 04:02 AM
Hi guys,
Ive got 17's on my MCS and run flats. Whats the best psi to have them set too? Also do yours tend to go down slightly over time? My warning light comes on every few months, but then i pump them up agaion and reset it and everything seems fine.
S
Old Apr 11th, 2007, 03:57 AM
scho06's Avatar
Road Hog!
Local Time: 11:02 PM
United States Male View scho06's Space Blue & Silver 1st Gen MINI Cooper S Profile
I believe the suggested psi for the the 17" is 35 all around. Most tires will lose air after long periods of time, or drops in temp., but not every few months. If you're warning light is coming on, then that means one of you tires is losing air faster than the others. I would say you have a slow leak In one of your tires. Next time the warning light comes on, check all four tires for pressure, I bet one is noticeably lower than the others.
Old Apr 11th, 2007, 07:08 AM
Japper's Avatar
Scotland View Japper's Pepper White & Black 2nd Gen MINI Cooper S Profile View Japper's Classified Ads
Quote: Originally Posted by Kingkelly (original)
Hi guys,
S
According to the label on the drivers door panel it should be 35psi all around, but I have run higher pressures on the rear on all my front wheel drive cars in an attempt to improve balance. On the MCS I run 32psi front and 37psi rear. I have covered 12k miles with this setup and when I swapped front to rear at 10k ( first service ) they were wearing even across the width. I have never had to top up pressures either, so i would guess you have a slow puncture.
57 Plate R56 PW/B MCS JCW Tuning Kit, Black R105's custom polished black, JCW Carbon fibre, JCW Recaro leather seats, Forge boost tube, Miltek DP, Factory JCW airbox & inlet pipe. Alta Panel filter, NM Eng engine mount. JCW Rear ARB
17" S Spokes...proper PSI? MaTTy_P Wheels, Tyres & Brakes 3 Jan 29th, 2005 10:58 AM
195/60/15 Psi Wentworth Wheels, Tyres & Brakes 2 Nov 21st, 2003 03:50 AM
47 psi??? david_75 Wheels, Tyres & Brakes 18 Oct 23rd, 2003 09:42 PM
psi minidriverUSA Wheels, Tyres & Brakes 2 Jun 29th, 2003 06:14 PM
psi for 18's The Helmet Wheels, Tyres & Brakes 0 Feb 14th, 2003 06:35 AM
