» Sponsors
» Sponsors
Go Back   MINI2 - MINI Forum > MINI Technical Forums > Wheels, Tyres & Brakes
MINI2.com is the largest MINI Forum on the internet. Registered Users do not see the above ads.
  #16 (permalink)
Old Apr 15th, 2007, 09:57 AM
Rakey's Avatar
Rakey
Total MINI dot com!!
Local Time: 03:14 AM
Quote: Originally Posted by Hat (original)
40,000 miles, give or take a couple of hundred. was recceing a route today rather gingerly i'll be getting it booked in next week, only 1200 miles to service anyway
get it booked in sooner rather than later, I went for about 2 weeks when mine came on
Want to buy some rear pads?
  #17 (permalink)
Old Apr 15th, 2007, 10:05 AM
T-bone S's Avatar
T-bone S
Local Time: 02:14 AM
Quote: Originally Posted by Root Ginger (original)
Technically they should probably be replaced before the light comes on.
Remember that the less pad you have the less area you have to dissipate heat = more likely to experience brake fade. Also the more heat the quicker the pad will wear.
The minimum recommended thickness of pads is 3mm. I don't know at what level the warning light comes on.
ditto - just had mine done front & rear - was done before the light came on - has started to feel it a little in the pedal. If the light comes on you'll also have to pay a little more to have the sensor replaced too.
MY05 MINI COOPER S - DS/B - GTT OPTIMISED- THANKS FOR THE RIDE - ENTER THE R56 JCW
  #18 (permalink)
Old Apr 15th, 2007, 06:12 PM
PmP's Avatar
PmP
GP 06 MCS 0380
Northern Ireland Male View PmP's Dark Silver & Black 1st Gen MINI Cooper S Profile
Quote: Originally Posted by burns863 (original)
Just a query on your brake fluid. How do you know it is due in 345 miles? As the indicator on the odometer for when your brake fluid is due a change is in days (........I think )
Your Mini's odd then, mine counts down in miles.
  #19 (permalink)
Old Apr 16th, 2007, 11:29 AM
Hat's Avatar
Hat
ITS RAINNIN' SIDEWAYS
England Male
i'm booked in tomorrow for the brakes & the last tlc service. there's only about 1200 miles to go to service so they agreed to do it at the same time.
it was a bit scary doing a run recce around the yorkshire dales on saturday with the warning light on
Brake pad warning light giler Wheels, Tyres & Brakes 11 May 30th, 2006 08:51 AM
Brake pad warning light ayohell First Generation Faults & Fixes 1 Jul 26th, 2005 02:04 PM
Brake Pad warning Light wow First Generation Faults & Fixes 21 Sep 7th, 2004 10:02 AM
Brake Pad Warning Light Problem Riteon First Generation Faults & Fixes 0 Sep 6th, 2004 01:16 PM
Brake pad warning light silver-mini-s First Generation MINI Cooper S 2 Jul 19th, 2004 04:16 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
