brake pad warning light - how long do i have left - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old Apr 13th, 2007, 07:06 PM
Hat's Avatar
Hat
ITS RAINNIN' SIDEWAYS
Local Time: 10:25 PM
England Male View Hat's Classified Ads
the brake pad warning light just came on on my dash, does anyone have an idea how long i have left before i need to get them changed?
Old Apr 13th, 2007, 07:09 PM
MINICooperMurph's Avatar
aka Nick
Send a message via AIM to MINICooperMurph Send a message via MSN to MINICooperMurph
how many miles you done?
Old Apr 13th, 2007, 07:12 PM
Chilli
Local Time: 09:25 PM
i was told by my dealer there is pleanty of time, but best get it booked in
Old Apr 13th, 2007, 07:24 PM
aka Nick
How many miles did you get Vic?
Saw you MINI mag by the way, well cool.
Old Apr 13th, 2007, 07:51 PM
nylo's Avatar
Totally Mental!
Northern Ireland Female View nylo's Space Blue & Silver 1st Gen MINI Cooper S Profile View nylo's Classified Ads
Pat, mine came on just before the Irish Job in Feb, and I phoned the dealer in a bit of a panic. He told me I'd another good couple of thousand miles in it. Don't know how many I actually did before getting them changed, but I did the whole IJ weekend +++ with it on, so no worries
Old Apr 13th, 2007, 09:32 PM
robbo mcs's Avatar
Track Addict
Local Time: 08:25 AM
Australia View robbo mcs's British Racing Green & White 1st Gen MINI Cooper S Profile
Hi,
It depends how aggressively you drive. If you drive conservatively you probably have quite a while. If you are a very spirited driver, it can go in a matter of minutes.
Bear in mind that if you do go metal on metal, then you will need new discs as well, which adds to the cost
Robbo
Mods: Hartge kit, CAI, oil cooler, headers, cat & exhaust, bilstein coilovers, adjustable bars & camber plates, quaife diff, roll cage, seats, harnesses
GO MADDIE and SPARKY!
Old Apr 13th, 2007, 09:36 PM
Chilli
mine hasent come on yet, had mot in jan and they said they would need doing quickfit did, but no light yet.
Old Apr 14th, 2007, 08:46 AM
goodingm's Avatar
Malcolm
Scotland Male View goodingm's Hyper Blue & White 1st Gen MINI Cooper S Profile View goodingm's Classified Ads
normally you have around 2000 miles left when the light comes on,but would depend on how you drive it also.
Old Apr 14th, 2007, 10:13 AM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
Technically they should probably be replaced before the light comes on.
Remember that the less pad you have the less area you have to dissipate heat = more likely to experience brake fade. Also the more heat the quicker the pad will wear.
The minimum recommended thickness of pads is 3mm. I don't know at what level the warning light comes on.
It was acceptable in the 80's
Old Apr 14th, 2007, 10:55 AM
Rallyepete's Avatar
United Kingdom Male View Rallyepete's Classified Ads
Also note that the sensor is only on one front/rear wheel (can't remeber which).
My light came on and went to replace the pads only to find the rear without a wear sensor had worn to the metal brakeshoe and scored the disc very slightly, so needing both discs replacing as well as the pads!
Old Apr 14th, 2007, 11:06 AM
zyo's Avatar
zyo
owt else is just traffic
I had something similar. Went to the dealers for it's service and they said the front pads and discs would shortly need replacing( odd how the discs wear at the same rate as the pads). Two days later the dash light cam on. I took it in and thedealer phoned to confirm that they were changing the rear pads. I said that the fronts were the ones for changing. They said it was the rears that had brought the warning light on as they were completely out (interesting how that wasn't picked up by the dealer at the service). I was also informed by MINI in an email that although their minimum thickness for the disc is 20mm, it is safe to put on new pads with the disc at 20mm thick. I don't understand that but i read the email a couple of times and thats what it says.
Old Apr 14th, 2007, 11:08 AM
Morri7's Avatar
Scotland Male View Morri7's Indi Blue & White 1st Gen MINI Cooper S Profile
I replaced my discs and pads before the warning light came on. The dealer had told me that they needed replaced. There was a small depth of friction material left on the pads but not much. If you replace before the light comes on then you don't have to buy a new sensor. Its a good opportunity to upgrade the brakes though. Get a set of Spiroslot discs and pads from GT Tuning they are ace!
Old Apr 14th, 2007, 06:42 PM
Hat's Avatar
Hat
40,000 miles, give or take a couple of hundred. was recceing a route today rather gingerly i'll be getting it booked in next week, only 1200 miles to service anyway
Old Apr 14th, 2007, 07:01 PM
PmP's Avatar
PmP
GP 06 MCS 0380
Northern Ireland Male View PmP's Dark Silver & Black 1st Gen MINI Cooper S Profile View PmP's Classified Ads
Mine came on after the mini2 run last tuesday. I'm guessing its the rear pads, as fronts were replaced after a track day at 24k miles. Got 46k miles out of the rears anyway.
Its booked in for this tuesday, and im guessing i'll need new pads on rear and discs front and rear. Also its a shame my brake fluid is due in 345 miles, and next oil service is in 4500 miles. So im gonna be in and out a bit .
  #15 (permalink)
Old Apr 14th, 2007, 09:31 PM
burns863's Avatar
The Muffin Man
Just a query on your brake fluid. How do you know it is due in 345 miles? As the indicator on the odometer for when your brake fluid is due a change is in days (........I think )
Brake pad warning light giler Wheels, Tyres & Brakes 12 May 26th, 2011 04:48 PM
Brake pad warning light ayohell First Generation Faults & Fixes 1 Jul 26th, 2005 03:04 PM
Brake Pad warning Light wow First Generation Faults & Fixes 21 Sep 7th, 2004 11:02 AM
Brake Pad Warning Light Problem Riteon First Generation Faults & Fixes 0 Sep 6th, 2004 02:16 PM
Brake pad warning light silver-mini-s First Generation MINI Cooper S 2 Jul 19th, 2004 05:16 PM
