| Can I swap from run flat to non run flats on a cooper s Hi guys my first post so be gentle with me .I have just purchased my first mini a 2003 52 plate cooper s fitted with 17 inch rims and run flat tyres.One of my rear tyres has a slow puncture and needs inflating every few days. Can anyone let me know can run flats be repaired, can I change run flats for non run flats if so do they all have to be 1 or the other.What are the benefits of either t yre and can anyone reccomend where to get the tyres. Thanks for any help. Cheers |
| Hello, there's a lot of information in the http://www.mini2.com/forum/faq.php FAQ section on wheels, tyres, runflats, repairs and options for replacements. This thread was also moved into the wheels and tyres forum for you, to get better, more accurate replies. Welcome to MINI2. |
FAQ: Can punctures to run flat tires be repaired? FAQ: What should be considered when replacing two tires? Last edited by MINIAC; Apr 21st, 2009 at 05:21 PM. |
| I have a new shape cooper S - I am shocked by how bad run flats are, it is blighting my enjoyment of the bar - it feels dead with way too much torque steer. Thankfully the they need changing soon - I won't be putting them back on. Anyone here done the same and can recomend some decent tyres for the car?? |
| I've just made the swap to non run flats on 17" S-lites. The tyres i chose were 215/40/17 Falken ZE512. (So far so good!) Tyres at mytyres.co.uk: car tyres, 4x4 tyres and van tyres at low prices is a good start. You can enter your required size and it will list the available tyres. Once you have chosen a tyre, enter your postcode and it provides a list of fitters in your area. Might be worth giving them a ring first to see if they're ok with taking run flats off though. I do not recommend using Wilco Motosave. I think they used a hammer and chisel to get my tyres off with the mess they made of my alloys. Anyway, that's another story. The main advantage of non run flats for me is the cost. It cost me £260 for 4, opposed to over £700 for a set of run flats. The obvious benefits of run flats are safety and convenience if you happen to get a puncture. There's a good few threads on here discussing the pros and cons so have a browse. |
| Tags: flats, non, run |
| Run Flat v's Non Run Flat.....Ride Quality | Mini Soph | Wheels, Tyres & Brakes | 84 | Oct 17th, 2006 07:23 PM |
| Run flats versus non-run flats | tceditor | Wheels, Tyres & Brakes | 10 | Apr 26th, 2006 10:49 AM |
| swap out new run flats? | egb | Wheels, Tyres & Brakes | 0 | Aug 31st, 2005 09:56 PM |
| MCS - Pirelli, Eufori run flats - flat spotting - vibration | dark silver | Wheels, Tyres & Brakes | 1 | Mar 5th, 2004 10:25 PM |
| Run-flats on a Cooper | Crawdad | Wheels, Tyres & Brakes | 12 | Oct 1st, 2002 10:01 AM |
