Brake Pedal Hissing - Goes rock hard - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
Old May 21st, 2007, 08:25 PM
20thebear's Avatar
Local Time: 01:45 PM
Male View 20thebear's Classified Ads
Can someone please tell me what may be wrong with my car?
It started tonight, when i press my brake pedal there is a hissing, air being squeezed out noise. At first I thought it was the brake fluid being sprayed out, but the brakes are still working ok. I heard the noise over the road noise with the window open and the radio on.
I stopped the car (kept the engine running) and pumped the brake and the noise happened every time.
I then turned the engine off and pumped the brake again and the pedal went rock hard.
Reading on here it could be something to do with the servo valve i think, but can anyone give me a full description so i know what to say when i take it to the garage?
thanks
Old May 21st, 2007, 10:00 PM
Gristy's Avatar
Always on Overboost
Local Time: 02:45 PM
England Male View Gristy's Chili Red & White 2nd Gen MINI Cooper S Profile View Gristy's Classified Ads
Could be the brake booster
One way to check it is to pump the pedal when the engine is off (it should go hard after about 3 pushes) keep your foot pressed on the pedal, turn the engine on and you should feel the pedal go done a bit.
Would have the brakes checked if you feel there is something not right/different
Tags: , , , ,
Brake pedal Yui First Generation Faults & Fixes 7 Dec 9th, 2010 02:12 PM
Between a Rock and a Hard Place...Help MaTTy_P General Discussion 8 Apr 2nd, 2007 06:28 PM
Problem with brake pedal yoni99 Wheels, Tyres & Brakes 6 Apr 27th, 2006 03:14 PM
Brake pedal- hissing sound mini2greece Wheels, Tyres & Brakes 1 Sep 2nd, 2005 07:29 PM
Ticking felt through brake pedal on hard braking - NOT ABS ButtonIt First Generation Faults & Fixes 10 Jun 27th, 2004 12:28 PM
