Goodyear Eagle F1s - Which? - Page 3 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Sponsored by:
  #31 (permalink)
Old Aug 30th, 2007, 01:20 PM
JohnWB's Avatar
Local Time: 04:35 PM
United Kingdom Male View JohnWB's Laser Blue & Black 2nd Gen MINI Cooper S Profile
Quote: Originally Posted by minicabrio (original)
What do you base that on? Have you driven different sizes back to back on the same car?
Choosing the 215/45 over the standard 205/45 will increase the radius of the wheel and tyre by 1.46% - this means that at an indicated 70mph you'll actually be doing 71.02mph.
If instead you choose the 215/40 over the standard 205/45, you will actually reduce the radius of the wheel and tyre by -2.03%. This means that at an indicated 70mph, you'll actually be doing 68.58mph.
I run the 215/40's, the grip is much improved over standard, but then it would be running non-runflats, handling is much improved, but then again it would be, and again comfort is also improved.
Using you own figures, the difference between the standard MINI 17 inch tyre & the 215/45 is 1.46%, whereas the diference for the 215/40 is 2.03% which is further away form the optimal size as detrmined by MINI
The difference is not very much but the lower sidewall hight tends to give a stiffer ride and slightly less roll
Both sizes are much better than the runflats and the majority of people have tended to go for the 215
Laser Blue / Black MCS - Arived March 07
  #32 (permalink)
Old Aug 30th, 2007, 11:09 PM
minicabrio's Avatar
Soon to be deleted !!
United Kingdom Male View minicabrio's Space Blue & Silver 1st Gen MINI Cooper S Profile
Using the stats from MINI2.... available here:
73 people have changed to 215/40 R17 non-runflats
70 people have changed to 215/45 R17 non-runflats
Both much better than standard
  #33 (permalink)
Old Aug 31st, 2007, 09:29 AM
JohnWB's Avatar
Sorry, you must have misunderstood me, I was only quoting for the Goodyears Eagle F1,
Using the table you mentioned
6 people have changed to Goodyear Eagle F1 215/40 R17 non-runflats
12 people have changed to Goodyear Eagle F1 215/45 R17 non-runflats
But these figures are probably out of date
New tyres but problem! :( (mini review of Eagle F1s too!) Cooooooperslad Wheels, Tyres & Brakes 5 Jul 7th, 2007 07:19 PM
Goodyear Eagle F1s on 18" wheels philip rodney Wheels, Tyres & Brakes 3 Sep 5th, 2006 01:20 PM
Goodyear Eagle F1s are awesome MarkW19 Wheels, Tyres & Brakes 72 Aug 13th, 2006 12:03 AM
VOLK SE37K and Goodyear Eagle F1s just fitted!!! Andreas01 Wheels, Tyres & Brakes 4 Jul 21st, 2006 09:38 AM
Bye Bye Runflats Hello Goodyear Eagle F1s TallAndy Wheels, Tyres & Brakes 3 Jun 19th, 2005 06:59 PM
