Visit Derek Woodman MINI
Tags: , , ,
Old Jun 16th, 2007, 05:11 PM   #1
james 3200
Local Time: 08:12 AM
Alloy repair in London / Surrey
Been looking for a company that can repair one of my curbed alloys, it has a diamond cut finish on the rim. The damage is light, but noticeable, to me anyway..
Anyone know of any, as most i have found are up north or not in my area
Many thanks,
James
England   Reply With Quote
Old Jun 28th, 2007, 03:57 AM   #2 (permalink)
LittleHawaiiRentals
MINI Renter in Paradise
Local Time: 09:12 PM
I found a guy out here in Hawaii (sorry, I know that doesn't do you much good) who wants to charge me $100 for EACH scratch to grind it and paint over it. I heard he does a good job, but was wondering how hard this might do myself. Does anyone know about this process? What kind of grinder & paint are used for alloy rims?
Kenric
www.LittleHawaiiRentals.com - Hawaii's MINI rental company
We're on a fun tropical island.....let's drive like it!
Old Jun 28th, 2007, 12:24 PM   #3 (permalink)
kalv
kalv's Avatar
If you want to do normal alloys then it's easy to do yourself. Buy your self some paint thinner.. some sand paper (wet & dry.. 200 grit up to 800 grit).. some filler.. laquer and some silver spray (einszett Car Care Products | Wash).. i used the silver wheel laquer as it's close to OEM for nearly all german cars...
Start by cleaning the alloy with normal car wash soap/water.
Then dry it and clean it again with the paint thinner.
Get the 200-grit sandpaper and sand it back to take the rough layer off (only scratch area)
Clean again with thinner.
Mix the filler and apply a small bit (if use too much then takes longer to sand off)
Allow it to dry
Use the 400-grit and sand back until nice and smooth
Clean again
If ok, then can move onto laquer, else apply more filla and repeat step.
Mask off wheel and tyre and anything else in the way (spend some time here!)
Clean again
Spray the laquer over the section - pressing the button on and off and NOT using a continous stream of spray
Alloy to dry
Once dry, get the 800-grit (wet!) paper and sand the laquer back until nice and smooth
Clean again
Spray with silver spray using a stop/start motion with the button
There you go!
"bhp sells cars, torque makes them move..."
Mini Cooper Chilli in Silver only £7995! with FSH Surrey/London rallycross For Sale 1 Aug 15th, 2006 01:26 PM
Alloy wheel repair Birdog Wheels, Tyres & Brakes 3 Jun 13th, 2006 10:43 PM
Recommended Bodyshop SW London / Surrey yidaho Exterior 7 May 1st, 2006 12:56 AM
can you repair a kerbed alloy? taz2822 Wheels, Tyres & Brakes 10 Aug 2nd, 2004 09:09 PM
Alloy Wheel Repair. Austin Wheels, Tyres & Brakes 3 Dec 10th, 2002 07:46 PM
